tolerance in simpleFoam
Old   August 25, 2022, 05:31
Question tolerance in simpleFoam
FluidKo is on a distinguished road
solvers
    p
        solver          GAMG;
        smoother        GaussSeidel;
        tolerance       1e-6;
        relTol          0.1;
    "(U|k|omega|epsilon)"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-6;
        relTol          0.1;
SIMPLE
    residualControl
        p               1e-4;
        U               1e-4;
        "(k|omega|epsilon)" 1e-4;
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
potentialFlow
    nNonOrthogonalCorrectors 10;
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.7;
        "(k|omega|epsilon).*" 0.7;
Hello everybody~
I'm wondering tolerance in simpleFoam.
Upper code is one of simple algorithm codes in tutorial file.
In this code, there are 2 types of tolerance.
One is tolerance in 'solvers' part and another is tolerance in 'residualControl' part.
I want to know difference between them.
Acutally I've learned PIMPLE algorithm before.
For the case of PIMPLE algorithm, I know difference between tolerance in 'solvers' part and tolerance in 'residualControl' part.
Tolerance in 'solvers' part is criteria of residual for pressure correction(inner loop) and tolerance in 'residualControl' part is criteria of residual for momentum prediction(outer loop).
But for the case of SIMPLE algorithm there is only momentum prediction(outer loop), not pressure correction(inner loop).
Even though there is only momentum prediction, why there can be 2 criterias(tolerance in 'solvers' and tolerance in 'residualControl')?
What is difference between them for SIMPLE algorithm?
Thank you~!
FluidKo is offline   Reply With Quote
residual, simple algorithm
tolerance in solver VS tolerance in residualControl FluidKo OpenFOAM Running, Solving & CFD 13 January 30, 2024 11:59
SimpleFoam Stops Without Error Message MoeCFD OpenFOAM Running, Solving & CFD 12 July 20, 2022 06:49
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 16:26
STL import is not working zordiack enGrid 9 July 1, 2014 15:49
High pressure residual simpleFoam CiccioPasticcio OpenFOAM Running, Solving & CFD 6 March 5, 2013 22:20
