How to make water flow for solver interFoam using alpha.water?
Old   August 20, 2022, 02:04
Default How to make water flow for solver interFoam using alpha.water?
Gavin.
GavinRe is on a distinguished road
Note: I am sorely new to Linux subsystem and openFOAM, so please excuse the incorrect terms I used.
My simulation is based on the $FOAM/tutorials/multiphase/interFoam/RAS/weirOverflow/
I am trying to simulate open channel flow passing through a vertical cylinder. You can download my file from this link >> LINK
I run using the commands:
blockMesh
checkMesh
//redefine defaultFaces in "polyMesh/boundary" file to "empty".
setFields
interFoam
I can execute all those commands, however when running the solver, it always stop halfway and when I execute paraFoam, I found that the water is just... there. No flow movement whatsoever.
I have tried reducing the time taken (time step? in controlDict), as well as reducing the inletFlowRate. Yet, it still resulted the same.
I have an inkling that I need to add several more boxes to my setFields, as my blockMeshDict have extra zones (refer to image attached) when compared to the one in the tutorial. But I have no idea on what coordinates to put so that it can flow properly.
GavinRe is offline   Reply With Quote
alpha.water, interfoam, weiroverflow
[IHFOAM] The IHFOAM Thread Phicau OpenFOAM Community Contributions 392 September 8, 2023 19:10
unable to run dynamic mesh(6dof) and wave UDF shedo Fluent UDF and Scheme Programming 0 July 1, 2022 18:22
water injection error (modify the position of water injection) wjchoi Main CFD Forum 0 January 17, 2022 08:17
Mass imbalance problem in multiphase water and steam CFX case Antech CFX 1 October 26, 2020 05:03
Flow water in channel with zero speed illia Fluent Multiphase 0 March 21, 2018 08:30
