How to use waveMakerPiston and irregularMultiDirectional in openfoam ?
Old   August 16, 2022, 11:21
Default How to use waveMakerPiston and irregularMultiDirectional in openfoam ?
cfd_saad is on a distinguished road
Hi Foamers,
I am studying a breakwater and I would like to generate irregular waves (JONSWAP spectra), I found in the tutorials, in the waves folder the following :
- waveMakerPiston, uses a dynamic mesh with the following pointDisplacement file in 0.orig :
|  \\    /   O peration     | Version:  v2012                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       pointVectorField;
    object      pointDisplacement;
dimensions      [0 1 0 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    bottom1
        type            zeroGradient;
    bottom2
        type            fixedValue;
        value           uniform (0 0 0);
    leftwall
        type            waveMaker;
        motionType      piston;
        n               (1 0 0);
        waveHeight      0.06;
        initialDepth    0.25;
        wavePeriod      2.0;
        rampTime        2.0;
        wavePhase       0;
    back
        type            empty;
    front
        type            empty;
    rightwall
        type            fixedValue;
    top
        type            zeroGradient;
The conditions in the leftwall, generate only one wave ? How can I generate multiple waves by indicating the speed in x and y of the piston ?
- irregularMultiDirectional, generates irregular waves in a static mesh, I don't understand how this file works, how can I input a JONSWAP type spectra in this file ?
I don't post it here because it is too long (it is here in waveProperties file : https://develop.openfoam.com/Develop...ction/constant )
Thanks!!
cfd_saad is offline   Reply With Quote
Old   August 18, 2022, 09:53
any ideas ?
Old   August 24, 2022, 05:40
here you can found information on how to generate irregular waves with a piston and without a piston :
https://knu.readthedocs.io/en/latest...eurPiston.html
