Transonic flow, 2D compressor blade
Old   August 15, 2022, 13:17
Default Transonic flow, 2D compressor blade
DOP
Panov Dmitrii
DOP is on a distinguished road
Hi all,
I am trying to calculate transonic flow around the 2D compressor blade. And i'm stuck: solver crashing or solution don't convergence. I tried roSimpleFoam and roPimpleFoam. Are there better solvers for such type of transonic flow? I will also be grateful if someone can share experience in calculating the transonic flow in a compressor using standard OpenFOAM solvers.
DOP is offline   Reply With Quote
Old   August 15, 2022, 13:33
Domenico Lahaye
dlahaye is on a distinguished road
Convergence of rhoS/PimpleFoam is indeed delicate.
We found boundary condition settings crucial.
How are you setting boundary conditions for pressure, density and temperature on the inlet and outlet patches?
dlahaye is offline   Reply With Quote
Old   August 18, 2022, 05:37
DOP
Panov Dmitrii
Hello, Domenico
Thank you for your reply and a fresh look at the problem. I changed the fixed values BC to total pressure and velocity direction and now everything works. I jast tried to get solution for stall rigion. This is validation case so i will share results when will get.
Old   August 18, 2022, 08:02
Domenico Lahaye
Wonderful! Well done! I look forward to seeing your results.
Will the results of steady state solver and transient solver be same? carye OpenFOAM Running, Solving & CFD 9 December 28, 2019 06:21
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate MSchneid Fluent UDF and Scheme Programming 3 February 23, 2019 07:00
Why transonic flow is highly nonlinear? TurbJet Main CFD Forum 15 January 8, 2019 16:13
Unbale to get stable transonic flow Alex Siemens 0 February 11, 2009 07:03
Simulation of transonic flow over NACA0012 airfoil MSc Student Siemens 2 August 9, 2006 14:49
