Anon
Rep Power: 5 ![]() |
Hi All,
I had a simulation running with an inlet direction of ~45 degrees and the simulation converged no problem. I had another simulation to run using exactly the same domain with an inlet direction of ~64 degrees, and an error occurs at the inlet where a portion of flow is nearly 0 and flows the opposite direction, I have attached 4 images, the starting 45 degree boundary condition and it again halfway through the simulation as well as the start of the 64 degree boundary condition and how it looks halfway through the simulation. Nothing has changed in the domain, I've tried re blockmeshing and SHM, but the same error occurs. If anyone could advise that would be greatly appreciated Cheers |
boundaries, inlet bc, running error |
Wind tunnel flow simulation boundary condition issue | charan3007 | SU2 | 0 | October 21, 2021 08:27 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 01:44 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
