Dimension Problem after overPotentialFoam
Old   August 8, 2022, 10:04
Default Dimension Problem after overPotentialFoam
hbulus is on a distinguished road
Hello everyone,
I am using OFV1912. I am planning to 6dof analysis by overset. As a first step;
i will get steady solution, therefore first i'll do initialization with overPotentialFoam then overRhoSimpleFoam.
As it is understood from solver names, analysis will be with compressible flow.
However, after initialization, the created Phi file has a dimension of m^3/s, it should be kg/s for compressible flow.
Is there anyone why overPotentialFoam gives dimensions for incompressible flow? Is this a bug? What do you suggest to solve this problem ?
hbulus is offline   Reply With Quote
fluidized bed dimension problem thomas007 FLUENT 0 December 6, 2016 09:59
Heat Transfert, mixing problem Wazdq CFX 8 November 7, 2016 06:44
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
