High Turbulent channel (duct) flow - a lot of problems |
August 5, 2022, 13:04 |
Hi guys! 1st post for me here at CFD-Online.
Great community , great people, thanks! I'm currently trying to stabilize a simulation that doesn't want to "stay calm" -------- > EXPLOSION I've a channel duct flow:
Thanks Pao |
August 7, 2022, 04:39 |
Santiago Lopez Castano
Rep Power: 15 |
August 8, 2022, 03:08 |
Rep Power: 4 |
Without additional information it's hard to say why your simulation crashes, so I can suggest some general things to check that might be the cause: - Does it crash at the first few iterations or at a certain time? - You could examine the log file, or monitor the residuals (https://doc.cfd.direct/openfoam/user...phs-monitoring) to find out which variable causes the problem (p,T,U etc.). - Is your mesh fine? Are there any bad cells (use checkMesh) - How did you calculate the BC for the turbulence model? You can estimate appropriate values e.g. at https://cfd-training.com/turbulent-b...ns-calculator/ Hope that helps, good luck! |
channel flow, high turbulence, rhosimplefoam |
Code for EARSM by Hellsten and RSM by Manceau, square duct, 2d turbulent channel | Thomas Baumann | OpenFOAM Running, Solving & CFD | 14 | October 16, 2020 04:11 |
Calculate statistics of Turbulent channel flow with LES | sjwon1991 | Main CFD Forum | 2 | May 10, 2016 23:31 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 06:44 |
flow with high turbulent viscosity ratio | Phillips | FLUENT | 0 | August 24, 2008 18:01 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
