Implementation of the Bird-Carreau-Yasuda rheology model |
Rep Power: 5 ![]() |
Hello Everyone,
In an attempt to conduct a comparison of different non-newtonian models for studying blood flow, I was wondering if anyone has an idea on how I can acquire the Bird-Carreau-Yasuda model, by changing the constant "a" from the default value of 2, to my preferred one (see https://doc.cfd.direct/openfoam/user...sport-rheology, OF-version7). According to BirdCarreau.H it is possible to do that ("The Bird-Carreau-Yasuda form is also supported if the optional "a" coefficient is specified. "a" defaults to 2 for the Bird-Carreau model"). However, when I tried to add "a" as (a [ 0 0 0 0 0 0 0 ] 0.5; ) in the BirdCarreauCoeffs sector, the simulation failed, since it expected a word. It actually seems that it doesn't recognize "a" as an option to be set. Does this mean that a modification of the source-code is required, or am I missing something? Thank you in advance. Paul |
Rep Power: 14 ![]() |
I succesfully programmed and run almost daily the German Carreau Model, but with ESI OF (v2206). So could you quote your sourcecode and your case so we can have a look? For my Carreaumodel i added a .lib in the run folder and include it in the controlDict.
Thanks for the quick reply,
I am attaching the .C and .H files and my transportProperties file which you can add in any case to check whether it works. |
Sheetal
Rep Power: 3 ![]() |
Hello everyone
I am working on non Newtonian fluids and I need Bingham model or Papanastasiou method for my case but openfoam does not have these model. I make changes in the source file of Bird Carreau model so that it works like Papanastasiou method. I change the viscosity function and the variables. But when I run the case, I got the error given below. I already remove the variable nu0 from the source files wherever it is mentioned. This indicates me that solver is not considering the changes which I made in the Bird Carreau model. --> FOAM FATAL IO ERROR: (openfoam-2312 patch=240220) Entry 'nu0' not found in dictionary "/home/sheetal/tutorials/incompressible/BirdCarreauPoiseuille/constant/transportProperties/BirdCarreauCoeffs" file: constant/transportProperties/BirdCarreauCoeffs at line 27 to 28. From bool Foam::dimensioned<Type>::readEntry(const Foam::word&, const Foam::dictionary&, Foam::IOobjectOption::readOption, bool, Foam::keyType: ![]() in file ./src/OpenFOAM/lnInclude/dimensionedType.C at line 104. FOAM exiting Any help and suggestions will be appreciated. Thanks in advance. |
bird-carreau-yasuda |
Implementation of turbulent algebraic heat flux model | Fabio1893 | OpenFOAM Programming & Development | 24 | December 30, 2021 02:08 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
[swak4Foam] swakExpression not writing to log | alexfells | OpenFOAM Community Contributions | 3 | March 16, 2020 18:19 |
[blastFoam] Implementation and Validation of the JWL++ Reactive Flow Model | trbrewer | OpenFOAM Community Contributions | 0 | January 27, 2020 15:25 |
implementation of Spalart-Allmaras Turbulence Model | zhengjg | Main CFD Forum | 0 | July 24, 2013 03:43 |
