August 4, 2022, 12:41 |
Variable saturation temperature
Rep Power: 4 |
Hello foamers !
I'm currently using interCondensatingEvaporatingFoam, a multiphase flow with phase change. In the thermophysical properties, the saturation temperature TSat is a scalar and is constant but as my simulation runs, the pressure increases in the whole domain and it should be the same for the saturation temperature. I would like the saturation temperature to change with pressure, for example using a two column csv file. The problem is that I know how to do it against time for limits, but not against pressure. Has anyone done something similar and could help me? Thanks ! |
csv file, saturation temperature, thermophysical properties, variable |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 10:21 |
Evaporation condensation below saturation temperature in FLUENT | user321 | Fluent Multiphase | 1 | January 29, 2020 06:41 |
Below Saturation Temperature Evaporation | amit.garg | FLUENT | 0 | May 11, 2015 04:59 |
UDF for variable temperature with time | CaglarCoskun | Fluent UDF and Scheme Programming | 8 | January 15, 2014 10:15 |
how is it possible: temperature higher than saturation temperature??? | domino | FLUENT | 0 | October 6, 2010 07:16 |
