July 27, 2022, 11:50 |
simpleFoam not converging?
Rep Power: 4 |
I've been trying to get a custom case running using simpleFoam - the case is in theory quite simple, one fixed pressure inlet and one fixed velocity outlet (that I will later swap in for a fixed volumetric flow rate outlet). The simpleFoam solver seems to end early without convering, output below. Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.01 field U tolerance 0.001 field "(k|epsilon|omega|f|v2)" tolerance 0.001 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Selecting laminar stress model Stokes No MRF models present No finite volume options present Starting time loop Time = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0294685, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0668456, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.0747838, No Iterations 2 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0184127, No Iterations 2 GAMG: Solving for p, Initial residual = 0.452291, Final residual = 0.0186042, No Iterations 1 GAMG: Solving for p, Initial residual = 0.0913773, Final residual = 0.00562931, No Iterations 1 time step continuity errors : sum local = 8.32867e-07, global = -2.72535e-14, cumulative = -2.72535e-14 ExecutionTime = 0.058 s ClockTime = 0 s Time = 2 smoothSolver: Solving for Ux, Initial residual = 0.695821, Final residual = 0.0251763, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.632267, Final residual = 0.0188064, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.360745, Final residual = 0.0117506, No Iterations 2 GAMG: Solving for p, Initial residual = 0.567775, Final residual = 0.0469497, No Iterations 1 GAMG: Solving for p, Initial residual = 0.140186, Final residual = 0.0123325, No Iterations 1 GAMG: Solving for p, Initial residual = 0.034633, Final residual = 0.00218083, No Iterations 2 time step continuity errors : sum local = 2.41008e-07, global = 5.57529e-12, cumulative = 5.54804e-12 ExecutionTime = 0.069 s ClockTime = 0 s Time = 3 smoothSolver: Solving for Ux, Initial residual = 0.567759, Final residual = 0.0244518, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.491631, Final residual = 0.027497, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.281927, Final residual = 0.00766034, No Iterations 2 GAMG: Solving for p, Initial residual = 0.136629, Final residual = 0.0119827, No Iterations 1 GAMG: Solving for p, Initial residual = 0.0586256, Final residual = 0.004022, No Iterations 1 GAMG: Solving for p, Initial residual = 0.0136292, Final residual = 0.000861313, No Iterations 2 time step continuity errors : sum local = 1.42179e-07, global = 1.59204e-11, cumulative = 2.14684e-11 ExecutionTime = 0.081 s ClockTime = 0 s Time = 4 smoothSolver: Solving for Ux, Initial residual = 0.424208, Final residual = 0.00987025, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.397932, Final residual = 0.0125944, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.120651, Final residual = 0.00666165, No Iterations 2 GAMG: Solving for p, Initial residual = 0.0942463, Final residual = 0.00665727, No Iterations 1 GAMG: Solving for p, Initial residual = 0.0289666, Final residual = 0.00104403, No Iterations 2 GAMG: Solving for p, Initial residual = 0.0095302, Final residual = 0.000736445, No Iterations 1 time step continuity errors : sum local = 1.34236e-07, global = 2.93937e-11, cumulative = 5.08622e-11 ExecutionTime = 0.093 s ClockTime = 0 s *** continues a bit *** Time = 113 smoothSolver: Solving for Ux, Initial residual = 0.643398, Final residual = 0.0500197, No Iterations 12 smoothSolver: Solving for Uy, Initial residual = 0.65007, Final residual = 0.0483867, No Iterations 5 smoothSolver: Solving for Uz, Initial residual = 0.71876, Final residual = 0.0614276, No Iterations 4 GAMG: Solving for p, Initial residual = 0.732957, Final residual = 0.0433888, No Iterations 2 GAMG: Solving for p, Initial residual = 0.608711, Final residual = 0.0317925, No Iterations 1 GAMG: Solving for p, Initial residual = 0.499677, Final residual = 0.0171388, No Iterations 1 time step continuity errors : sum local = 1.66446, global = -0.0479148, cumulative = -0.0450688 ExecutionTime = 1.369 s ClockTime = 1 s Time = 114 smoothSolver: Solving for Ux, Initial residual = 0.656116, Final residual = 0.0442092, No Iterations 28 smoothSolver: Solving for Uy, Initial residual = 0.644418, Final residual = 0.0452629, No Iterations 34 smoothSolver: Solving for Uz, Initial residual = 0.631059, Final residual = 0.0511848, No Iterations 31 GAMG: Solving for p, Initial residual = 0.9998, Final residual = 0.0843136, No Iterations 3 GAMG: Solving for p, Initial residual = 0.994701, Final residual = 0.000595515, No Iterations 1 GAMG: Solving for p, Initial residual = 0.899573, Final residual = 7.32625e-05, No Iterations 1 time step continuity errors : sum local = 3.97051e+06, global = -10147.3, cumulative = -10147.4 ExecutionTime = 1.387 s ClockTime = 1 s Time = 115 smoothSolver: Solving for Ux, Initial residual = 0.740435, Final residual = 0.0571045, No Iterations 47 smoothSolver: Solving for Uy, Initial residual = 0.740483, Final residual = 0.0687116, No Iterations 47 smoothSolver: Solving for Uz, Initial residual = 0.741827, Final residual = 0.0724437, No Iterations 52 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0998332, No Iterations 12 GAMG: Solving for p, Initial residual = 1, Final residual = 4.85116e-10, No Iterations 1 GAMG: Solving for p, Initial residual = 0.439633, Final residual = 9.28016e-11, No Iterations 1 time step continuity errors : sum local = 5.78855e+18, global = 7.63848e+17, cumulative = 7.63848e+17 ExecutionTime = 1.413 s ClockTime = 1 s Time = 116 smoothSolver: Solving for Ux, Initial residual = 0.614144, Final residual = 2.64685e+06, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = 0.612062, Final residual = 3.58646e+06, No Iterations 1000 smoothSolver: Solving for Uz, Initial residual = 0.76164, Final residual = 8.99608e+06, No Iterations 1000 - Change simulation type to Laminar - Change tubulence to off Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2206 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object turbulenceProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // simulationType laminar; RAS { // Tested with kEpsilon, realizableKE, kOmega, kOmegaSST, // ShihQuadraticKE, LienCubicKE. RASModel kEpsilon; turbulence off; printCoeffs on; } // ************************************************************************* // Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Time = 0 Mesh stats points: 2052 faces: 13345 internal faces: 9483 cells: 5707 faces per cell: 4 boundary patches: 3 point zones: 0 face zones: 0 cell zones: 1 Overall number of cells of each type: hexahedra: 0 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 5707 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 12 11 ok (non-closed singly connected) outlet 30 25 ok (non-closed singly connected) defaultFaces 3820 1921 ok (non-closed singly connected) Checking faceZone topology for multiply connected surfaces... No faceZones found. Checking basic cellZone addressing... CellZone Cells Points Volume BoundingBox fluid 5707 2052 631.946 (-8.84167 -6.3597 -5.27608) (4.55833 56.7699 3.56623) Checking geometry... Overall domain bounding box (-8.84167 -6.3597 -5.27608) (4.55833 56.7699 3.56623) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-2.57052e-18 1.1789e-17 9.14779e-18) OK. Max cell openness = 1.86801e-15 OK. Max aspect ratio = 346.237 OK. Minimum face area = 5.12208e-05. Maximum face area = 1.52766. Face area magnitudes OK. Min volume = 3.85096e-06. Max volume = 0.580758. Total volume = 631.946. Cell volumes OK. Mesh non-orthogonality Max: 87.5162 average: 28.9304 *Number of severely non-orthogonal (> 70 degrees) faces: 151. Non-orthogonality check OK. <<Writing 151 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 2.47004 OK. Coupled point location match (average 0) OK. Mesh OK. End - Increasing/decreasing nOrthogonal - Reducing the flow rate And none seem to have it converge. I wonder if someone has pointers about what I should be looking into to start learning how to solve this? Thank you! Here are my initial conditions p Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2206 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { outlet { type zeroGradient; } inlet { type fixedValue; value uniform 0; } defaultFaces { type zeroGradient; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2206 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { outlet { type fixedValue; value uniform (0 0 0.005); } inlet { type zeroGradient; } defaultFaces { type noSlip; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2206 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object k; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.375; boundaryField { outlet { type fixedValue; value uniform 0.375; } inlet { type zeroGradient; } defaultFaces { type kqRWallFunction; value uniform 0.375; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2206 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object nut; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type calculated; value uniform 0; } outlet { type calculated; value uniform 0; } defaultFaces { type nutkWallFunction; value uniform 0; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2206 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object nuTilda; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { outlet { type fixedValue; value uniform 0; } inlet { type zeroGradient; } defaultFaces { type zeroGradient; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2206 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object omega; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 -1 0 0 0 0]; internalField uniform 440.15; boundaryField { outlet { type fixedValue; value $internalField; } inlet { type zeroGradient; } defaultFaces { type omegaWallFunction; value $internalField; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2206 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object epsilon; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -3 0 0 0 0]; internalField uniform 14.855; boundaryField { outlet { type fixedValue; value uniform 14.855; } inlet { type zeroGradient; } defaultFaces { type epsilonWallFunction; value uniform 14.855; } } // ************************************************************************* // |
July 28, 2022, 00:08 |
Rep Power: 4 |
Here are two helpful videos:
https://www.youtube.com/watch?v=UM8I6CsVl4Y https://www.youtube.com/watch?v=zDFk0GCZG68 After watching those I tried the following: Removed all except p and U files from 0 (not necessary since turbulence model is laminar) And commented out the RAS portion of turbulenceProperties Code:
simulationType laminar; /* RAS { // Tested with kEpsilon, realizableKE, kOmega, kOmegaSST, // ShihQuadraticKE, LienCubicKE. RASModel kEpsilon; turbulence off; printCoeffs on; } */ This didn't converge either. I then changed the viscosity to 1e-3 and it converged in 36 steps. Since the modelled fluid viscosity is closer to 1e-6, I wonder if this means I need to refine the mesh further. I'll try that and see how it goes. |
July 28, 2022, 02:16 |
Lukas
Rep Power: 5 |
Hello Urchin your simple Simulation fails because of the very bad mesh : Orthogonality > 70 °
Try to remesh it you will not get a good convergence regardless of the solver settings. Another point is why you use a theth mesh? |
July 28, 2022, 07:29 |
Rep Power: 4 |
Hi Pappelau,
Thank you for the tip and you were indeed correct, the solution converges much better when I have a more refined mesh. I used Gmsh to import my CAD file and generate the mesh and it has defaulted to tets I believe. What would you recommend instead of a tetrahedral mesh? I picked it for no good reason to be honest and am happy to try and switch. Thank you for your help. |
July 28, 2022, 17:59 |
Rep Power: 8 |
Non-orthog. Quality larger than 85 is absolutely a no go. You should definitely remesh your geometry.
Generally, your mesh related error will be lower when your mesh cells are aligned with the flow. That is hardly the case for terahedral cells, but that should not mean that you can not use them, you need to adjust your fvSchemes entries accordingly. You can use snappyHexMesh to create a hexahedral dominant mesh, that will lower the cell count overall and speedup the simulation. |
July 29, 2022, 08:19 |
Lukas
Rep Power: 5 |
Try this workflow for further simulations :
CAD -> STEP (If u draw the CAD yourself u can directly use Salome) SALOME -> STL STL + blockMesh +SnappyHexMesh = Good Hexaedral Mesh This Workflow can be a rocky road, but there are very good Tutorials how to Mesh things from Wolfdynamics or Tobias Holzmann. Greetings Pappelau |
July 29, 2022, 08:34 |
Rep Power: 4 |
Thank you geth03 and Pappelau, looks like I have some more learning to do. I appreciate your help pointing me in the right direction.
convergence, laminar, simplefoam |
SimpleFoam Simulation for windtunnel is not converging | Wanting | OpenFOAM | 2 | July 29, 2022 12:08 |
simpleFoam is not converging at high flow rate | minzhang | OpenFOAM Running, Solving & CFD | 0 | July 10, 2020 15:58 |
kEspilon / simpleFoam - p non converging | KYPCK444 | OpenFOAM Running, Solving & CFD | 5 | February 27, 2018 10:25 |
SimpleFoam Case not converging | Doflo | OpenFOAM Running, Solving & CFD | 2 | December 18, 2014 13:09 |
simpleFoam parallel solver & Fluent polyhedral mesh | Zlatko | OpenFOAM Running, Solving & CFD | 3 | September 26, 2014 07:53 |
