How to make a simple Mixing plane in OpenFOAM plus
Old   July 23, 2022, 11:33
Default How to make a simple Mixing plane in OpenFOAM plus
ff
fxzf is on a distinguished road
Dear Foam experts,
I need to simulate a fan system. Geometry is not complicated, there is a axial fan in a channel, and a stator behind. This is illustrated in att.
Because I only need to simulate steady state, so I can only use the MRF in the rotor stage. But due to the stator behind, I need to use a mixing plane after rotor and before the stator. Now, the issue is I see there is no mixing plane in OpenFOAM plus version.
I know foam-ext has a mixing plane, but due to my most work is done in OpenFOAM plus, I cannot really move to use foam-ext unfortunately. I checked foam-ext code, mixing plane is much more complicated than my expected. There is also a mixingPlaneLduInterface.H in the code to somehow direct manipulate the matrix. I don't really understand it all in short time.
Because my geometry is quite simple, it is not aero-engine compressor which complicate AMI, transform needed. I can simulate the full fan geometry. So I wonder if it is possible to make a very simple mixing plane model in OpenFOAM plus. For example, could I use the Fan Cpt Jump boundary condition as reference, where I use master side to get flow from MRF stage, then calculate the mixing and put it into stator stage?
Thanks very much for the help.
fxzf is offline   Reply With Quote
Old   July 25, 2022, 06:24
ff
Anyone could give me some suggestions? Thanks.
Guidelines for running a mixing plane with a centrifugal compressor Andrew2 FLUENT 0 December 15, 2019 13:50
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
Mixing Plane Lee FLUENT 0 August 8, 2003 23:36
