Why does pressureInletOutletVeclocity require a velocity specification? |
July 22, 2022, 15:40 |
Rep Power: 4 |
Greetings,
I understand that pressureInletOutletVelocity, according to its description, says that it will assign zeroGradient to velocity for outflow and for inflow it will assign a velocity based on the flux in the patch normal direction. However, as far as I can tell, that's not what it really does. It doesn't compute and assign a velocity based on phi. It assigns a velocity value that you specify for "value". Right? |
August 28, 2022, 12:15 |
Joachim Herb
Rep Power: 22 |
The "value" from the boundary file is used only for initialization: https://github.com/OpenFOAM/OpenFOAM...torField.C#L76
Import .csv - velocity profile - error | eSKa | CFX | 9 | April 3, 2021 14:38 |
wrong velocity contour of rotating propeller - Fluent | calv | FLUENT | 1 | September 6, 2018 12:48 |
Problem with Velocity Poisson Equation and Vector Potential Poisson Equation | mykkujinu2201 | Main CFD Forum | 1 | August 12, 2017 14:15 |
atmBoundaryLayerInletVelocity - Velocity Profile not continuous through domain | sdfij6354 | OpenFOAM Running, Solving & CFD | 3 | July 26, 2017 17:16 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
