transient case diverges after steady state solution |
Rep Power: 4 ![]() |
Hello everyone,
I´m trying to simulate a fan for some time now using a frozen rotor approach as an initial solution for the transient case. The steady state case has satisfying results after about 1000 iterations. When I try to use this solution as the start of the transient case, the solution diverges immediately. I used this method before and it always worked fine, so I´m a bit confused now. The transient case works when started from 0 and uses the same mesh and turbulence model as the steady state case, so the problem seems to be the initial solution from the frozen rotor case. Has anyone encountered something similar before or has an idea how to solve it? |
Upgrading to v10 and using NCC instead of cyclicAMI solved the problem.
Transient Boundary Condition in Steady state solution | RAJDEEP | CFX | 3 | March 30, 2021 02:36 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
is it possible to predict how long it takes to reach steady state solution in unstead | Alimohamadi_nasr | CFX | 4 | November 11, 2013 06:11 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 14:37 |
