Adding new lookup parameter to OF21
Old   July 22, 2022, 01:42
Default Adding new lookup parameter to OF21
Farzad Faraji
farzadmech is on a distinguished road
Hello all
I want to add a new dimensionless parameter to pimpleFoam in OF21. I know that if I add these lines to OF6 or OF7, it will work, but it does not work in OF21;
 dimensionedScalar FFarzad
     "FFarzad",
     dimless,
     transportProperties.lookup("FFarzad")
Why these lines does not work in OF21? and what should I do?
Error;
pimpleFoamEpsilonGeneral.C: In function ‘int main(int, char**)’:
pimpleFoamEpsilonGeneral.C:205:6: error: ‘transportProperties’ was not declared in this scope
pimpleFoamEpsilonGeneral.C:205:6: note: suggested alternative: ‘transportModel_H’
      transportModel_H
In file included from pimpleFoamEpsilonGeneral.C:353:0:
Thanks,
Farzas
farzadmech is offline   Reply With Quote
Old   July 22, 2022, 02:52
überschwupper is on a distinguished road
The reason for that is, that the transport properties dictionary gets defined within the createFields.H file in OF6. I assume that it gets initialized somewhere else
Most probably this dictionary is defined elsewhere (after the createFields.H) file or within an object.
Since I'm not familiar with the ESI version, but maybe this will work out for you:
Make a reference to the dictionary
const dictionary& transportProperties = db().lookupObject<IOdictionary>("transportProperties");
and then your code snippet should work.
      "FFarzad",
      dimless,
It should also be possible to gain acces by following code, but I dont know exactly.
      "FFarzad",
      dimless,
      ).lookup("FFarzad")
Last edited by überschwupper; July 22, 2022 at 03:00. Reason: i dont get the formatting...
überschwupper is offline   Reply With Quote
Old   July 22, 2022, 23:00
Farzad Faraji
Thanks überschwupper. It worked, but what about scalar lookup?
I used below code and it gives me error;
   scalar prescribedTKE;
   prescribedTKE(transportProperties.lookup("prescribedTKE"));
Error;
pimpGeneral.C:217:61: error: ‘prescribedTKE’ cannot be used as a function
Thanks,
Farzad
Old   July 23, 2022, 04:25
Farzad Faraji
This solves the problem for scalars;
	IOdictionary transportProperties
    IOobject
        "transportProperties",
        runTime.constant(),
        mesh,
        IOobject::MUST_READ_IF_MODIFIED,
        IOobject::NO_WRITE
   transportProperties.lookup("prescribedTKE") >> prescribedTKE ;
Farzad
Error;
Thanks,
Farzad
Old   July 25, 2022, 05:21
Error;
Thanks,
Farzad
When you want to initialize your variable, then you need a declarator to use the direct initialization. If you want to seperate the declaration and the definition you have to use the assignment operator, otherwise it will be regocnized as a function.
scalar prescribedTKE(transportProperties.lookup<scalar>("prescribedTKE"));
should work fine.
lookup, new parameter, of21, openfoam2106
multiRegionHeater error ordinary OpenFOAM Running, Solving & CFD 2 June 9, 2020 18:43
Long output in terminal. ssa_cfd OpenFOAM Running, Solving & CFD 1 March 18, 2019 06:25
DPMFoam - Serious Error --particle-laden flow in simple geometric config benz25 OpenFOAM Running, Solving & CFD 27 December 19, 2017 21:47
conjugateHeatFoam + interFoam farhagim OpenFOAM Programming & Development 15 July 19, 2016 08:55
Convergence on anisotropic tetahedral meshes pbo OpenFOAM Running, Solving & CFD 12 December 14, 2010 12:59
