wallshearstress with icoFoam
Old   July 21, 2022, 20:02
Default wallshearstress with icoFoam
Nikolaos Beratlis
nikosb is on a distinguished road
I am a newbie to OpenFoam. I ran a laminar simulation of the flow around a sphere and I want to compute the wall shear stress and skin friction on the surface of the sphere. When I type
postProcess -func wallShearStress -time latestTime
I get this error message:
--> FOAM FATAL ERROR:
Unable to find turbulence model in the database
From function virtual bool Foam::functionObjects::wallShearStress::execute()
in file wallShearStress/wallShearStress.C at line 200.
From what I read the wallshearstress includes the turbulent shear stresses which in my case don't exist. How can I compute the wall shear stress on a laminar simulation ran with icoFoam?
nikosb is offline   Reply With Quote
Old   August 1, 2022, 11:26
sudo_rm is on a distinguished road
If you check the options for icoFoam you will see that there is no "postProcess" available
icoFoam:
Usage: icoFoam [OPTIONS]
options:
  -case <dir>       specify alternate case directory, default is the cwd
  -fileHandler <handler>
                    override the fileHandler
  -hostRoots <(((host1 dir1) .. (hostN dirN))>
                    slave root directories (per host) for distributed running
  -libs <(lib1 .. libN)>
                    pre-load libraries
  -listFunctionObjects
                    List functionObjects
  -listScalarBCs    List scalar field boundary conditions (fvPatchField<scalar>)
  -listSwitches     List all available debug, info and optimisation switches
  -listVectorBCs    List vector field boundary conditions (fvPatchField<vector>)
  -noFunctionObjects
                    do not execute functionObjects
  -parallel         run in parallel
  -roots <(dir1 .. dirN)>
                    slave root directories for distributed running
  -srcDoc           display source code in browser
  -doc              display application documentation in browser
  -help             print the usage
pimpleFoam:
Usage: pimpleFoam [OPTIONS]
options:
                    pre-load libraries
  -listFvConstraints
                    List fvConstraints
  -listFvModels     List fvModels
  -listMomentumTransportModels
                    List momentumTransportModels
  -noFunctionObjects
  -postProcess      Execute functionObjects only
I suggest using pimpleFoam or pisoFoam instead, and just set "laminar" in the momentumTransport properties.
Hope that helps,
sudo_rm is offline   Reply With Quote
Old   June 19, 2024, 08:28
Post
Alvaro
Lleo is on a distinguished road
Hi there!
I'm having the same problem when I submit the next comand:
Then it jumps the same error you mentioned.
Could you explain how did you obtain the solution for that case? I'm using simpleFoam instead, and runing a laminar flow case.
Thanks!
Lleo is offline   Reply With Quote
laminar, wall shear stress
postProcess Utility: icoFoam -noFunctionObjects Why?How? TeresaT OpenFOAM Post-Processing 8 July 26, 2023 03:41
icoFoam floating point exception (8) leizhao512 OpenFOAM Running, Solving & CFD 7 November 1, 2018 12:43
wallShearStress doesn't work in new solver (energy eq added in icoFoam) srv537 OpenFOAM Post-Processing 0 December 18, 2016 10:31
why does 'sample' do this? wallShearStress question CHARLES OpenFOAM Post-Processing 0 August 7, 2013 20:30
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
