Calculate maximum velocity components with functionObject
Old   July 18, 2022, 16:01
Default Calculate maximum velocity components with functionObject
TommyJ is on a distinguished road
I would like to compute the maximum of the u,v,z components of velocity with a functionObject.
I have been trying to use fieldMinMax as:
    fieldMinMax1
        // Mandatory entries (unmodifiable)
        type        fieldMinMax;
        libs        (fieldFunctionObjects);
        // Mandatory entries (runtime modifiable)
        mode        component;
        fields      (U);
        // Optional entries (runtime modifiable)
        location    true;
But so far I always get the same value for max and min at the same cell.
Does anyone know how to get the maximum/min of a component of a vectorField with a FO that will write the corresponding value to a log?
TommyJ is offline   Reply With Quote
Old   July 19, 2022, 05:56
Alczem is on a distinguished road
Hey,
I can't say about monitoring specific components of the vector, but I recently used the minMax function and what worked for me was the following :
        type                    fieldMinMax;
        //enabled                    true;
        libs                    ("libfieldFunctionObjects.so");
        writeControl            timeStep;
        //write                    true;
        //writeInterval           1;
        //writeToFile             yes;
        //log                     yes;
        location                yes;
        mode                    magnitude;
        fields                  (U p_rgh);
The mode field seems relevant here. Hope it helps.
EDIT: I forgot to mention that the output was written in a .dat file in postProcessing/fieldMinMax/0
Alczem is offline   Reply With Quote
Old   July 19, 2022, 09:53
Thanks for the reply, but the goal is to know where the maximum and minimum of each component is located. I am aware of the magnitude mode. I wounder if it would be possible to split the components with one functionObject and "feed" it to fieldMinMax.
Old   July 19, 2022, 12:57
Oh I see, well maybe you could use Paraview to output the values of each field and their components, and save this as a csv file. Then use Excel to sort the rows of your datasheet by the component value (that is what I would do if I needed to do it once or twice).
I did some reading to see if there was a way to access U's components directly through the fieldMinMax function (like U.component(0) or U.x) but no shot.
Sorry ! Maybe someone else can be more helpful
Old   July 19, 2022, 13:22
Originally Posted by TommyJ View Post
Apparently the last portion is possible :V... But I get all fields
    components1
        type            components;
        field           U;
    fieldMinMax1
        type        fieldMinMax;
        mode        magnitude;
        fields      (Ux);
        location    true;
time averaged and resolved velocity components raunakjung CFX 0 June 9, 2017 21:23
OpenFOAM Velocity BC two orthogonal components viv123 OpenFOAM 1 October 31, 2014 09:28
Plotting Radial and Circumferential Velocity Components for FSI modelling ashtonJ CFX 1 May 28, 2012 05:36
Compare 2D axi-symmetric and 3D. Is OpenFOAM calculate the velocity wrong? RalphS OpenFOAM 6 November 13, 2010 21:51
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
