July 17, 2022, 22:09 |
sloshingTank3D6DoF failed to run in parallel
Pei-Ying Hsieh
Rep Power: 18 |
It will be appreciated if someone can help me with this interFoam error when running sloshingTank3D6DoF case in parallel. Serial run was no problem. here are the error messages: Create time Create mesh for time = 0 Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: solidBody Applying motion to entire mesh Selecting solid-body motion function tabulated6DoFMotion PIMPLE: Operating solver in PISO mode Reading field p_rgh Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Selecting laminar stress model Stokes Reading g Reading hRef Calculating field g.h [14] [14] [14] --> FOAM FATAL IO ERROR: (openfoam-2206) [14] Unable to set reference cell for field p Reference point pRefPoint (0 0 0.15) found on 2 domains (should be one) [14] [14] [14] file: stream.PIMPLE at line 0. [14] [14] From [15] [15] [15] --> FOAM FATAL IO ERROR: (openfoam-2206) [15] Unable to set reference cell for field p Reference point pRefPoint (0 0 0.15) found on 2 domains (should be one) [15] [15] [15] file: stream.PIMPLE at line 0. [15] [15] From bool Foam::setRefCell(const volScalarField&, const volScalarField&, const Foam::dictionary&, Foam::label&, Foam::scalar&, bool) [15] in file cfdTools/general/findRefCell/findRefCell.C at line 90. [15] FOAM parallel run exiting [15] [0] [0] [0] --> FOAM FATAL IO ERROR: (openfoam-2206) [0] Unable to set reference cell for field p Reference point pRefPoint (0 0 0.15) found on 2 domains (should be one) [0] [0] [0] file: system/fvSolution.PIMPLE at line 81 to 87. [0] [0] From bool Foam::setRefCell(const volScalarField&, const volScalarField&, const Foam::dictionary&, Foam::label&, Foam::scalar&, bool) [0] in file cfdTools/general/findRefCell/findRefCell.C at line 90. [0] FOAM parallel run exiting [0] [1] [1] [1] --> FOAM FATAL IO ERROR: (openfoam-2206) [1] Unable to set reference cell for field p Reference point pRefPoint (0 0 0.15) found on 2 domains (should be one) [1] [1] [1] file: stream.PIMPLE at line 0. [1] [1] From bool Foam::setRefCell(const volScalarField&, const volScalarField&, const Foam::dictionary&, Foam::label&, Foam::scalar&, bool) [1] in file cfdTools/general/findRefCell/findRefCell.C at line 90. [1] FOAM parallel run exiting [1] [2] [2] [2] --> FOAM FATAL IO ERROR: (openfoam-2206) [2] Unable to set reference cell for field p Reference point pRefPoint (0 0 0.15) found on 2 domains (should be one) [2] [2] [2] file: stream.PIMPLE at line 0. [2] [2] From bool Foam::setRefCell(const volScalarField&, const volScalarField&, const Foam::dictionary&, Foam::label&, Foam::scalar&, bool) [2] in file cfdTools/general/findRefCell/findRefCell.C at line 90. [2] FOAM parallel run exiting [2] [3] [3] [3] --> FOAM FATAL IO ERROR: (openfoam-2206) [3] Unable to set reference cell for field p Reference point pRefPoint (0 0 0.15) found on 2 domains (should be one) [3] [3] [3] file: stream.PIMPLE at line 0. [3] [3] From bool Foam::setRefCell(const volScalarField&, const volScalarField&, const Foam::dictionary&, Foam::label&, Foam::scalar&, bool) [3] in file cfdTools/general/findRefCell/findRefCell.C at line 90. [3] FOAM parallel run exiting [3] [4] [4] [4] --> FOAM FATAL IO ERROR: (openfoam-2206) [4] Unable to set reference cell for field p Reference point pRefPoint (0 0 0.15) found on 2 domains (should be one) [4] [4] [4] file: stream.PIMPLE at line 0. [4] [4] From bool Foam::setRefCell(const volScalarField&, const volScalarField&, const Foam::dictionary&, Foam::label&, Foam::scalar&, bool) [4] in file cfdTools/general/findRefCell/findRefCell.C at line 90. [4] FOAM parallel run exiting [4] [5] [5] [5] --> FOAM FATAL IO ERROR: (openfoam-2206) [5] Unable to set reference cell for field p Reference point pRefPoint (0 0 0.15) found on 2 domains (should be one) [5] [5] [5] file: stream.PIMPLE at line 0. [5] [5] From bool Foam::setRefCell(const volScalarField&, const volScalarField&, const Foam::dictionary&, Foam::label&, Foam::scalar&, bool) [5] in file cfdTools/general/findRefCell/findRefCell.C at line 90. [5] FOAM parallel run exiting [5] [6] [6] [6] --> FOAM FATAL IO ERROR: (openfoam-2206) [6] Unable to set reference cell for field p Reference point pRefPoint (0 0 0.15) found on 2 domains (should be one) [6] [6] [6] file: stream.PIMPLE at line 0. [6] [6] From bool Foam::setRefCell(const volScalarField&, const volScalarField&, const Foam::dictionary&, Foam::label&, Foam::scalar&, bool) [6] in file cfdTools/general/findRefCell/findRefCell.C at line 90. [6] FOAM parallel run exiting [6] [7] [7] [7] --> FOAM FATAL IO ERROR: (openfoam-2206) [7] Unable to set reference cell for field p Reference point pRefPoint (0 0 0.15) found on 2 domains (should be one) [7] [7] [7] file: stream.PIMPLE at line 0. [7] [7] From bool Foam::setRefCell(const volScalarField&, const volScalarField&, const Foam::dictionary&, Foam::label&, Foam::scalar&, bool) [7] in file cfdTools/general/findRefCell/findRefCell.C at line 90. [7] FOAM parallel run exiting [7] [8] [8] [8] --> FOAM FATAL IO ERROR: (openfoam-2206) [8] Unable to set reference cell for field p Reference point pRefPoint (0 0 0.15) found on 2 domains (should be one) [8] [8] [8] file: stream.PIMPLE at line 0. [8] [8] From bool Foam::setRefCell(const volScalarField&, const volScalarField&, const Foam::dictionary&, Foam::label&, Foam::scalar&, bool) [8] in file cfdTools/general/findRefCell/findRefCell.C at line 90. [8] FOAM parallel run exiting |
May 18, 2023, 23:51 |
Nghiep
Rep Power: 4 |
Please change your parallel method. In this case, the Hierarchical is used. I have got the same problem, then change to scotch method. It is working well
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 03:35 |
"Failed Starting Thread 0" | ebringley | OpenFOAM Running, Solving & CFD | 2 | April 26, 2019 05:45 |
GAMG crash | fxzf | OpenFOAM Running, Solving & CFD | 6 | June 5, 2018 05:09 |
Problem to run simpleFoam using qsub? | be_inspired | OpenFOAM | 1 | December 22, 2015 12:53 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
