swimming fish FPE
Old   July 16, 2022, 18:42
Default swimming fish FPE
Bailey
bjavila1409 is on a distinguished road
I keep receiving the infamous sigFPE error (see below) and I cannot get this case to run for the life of me. I have a list of points defining a foil shape, which I am going to animate following the Chalmers myWaveDisplacement "Make A Fish Swim" using pimpleFoam. I took the list of points, made a 2D STL shape, extruded it in paraview, and saved the resulting "3D" shape. I am trying to use blockMesh to make a box around the shape, and then snappyHexMesh to get the shape into openfoam. Case files are below and picture of STL file is attached (it was too big to attach the actual STL file). Can anyone help me with this? I think it is an error with my p boundary conditions based on when it crashes but maybe not.
*if it matters, I am running Openfoam8 on my Mac
HTML Code:
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
#4  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
#5  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
#7  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/pimpleFoam"
#8  Foam::fvMatrix<double>::solve() in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/pimpleFoam"
#9  ? in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/pimpleFoam"
#10  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11  ? in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/pimpleFoam"
Floating point exception
bjavila1409 is offline   Reply With Quote
Old   July 16, 2022, 18:43
Default more files
Bailey
more files attached
Old   October 19, 2022, 04:14
kimy
qi.yang@polimi.it is on a distinguished road
Send a message via ICQ to qi.yang@polimi.it Send a message via AIM to qi.yang@polimi.it Send a message via Yahoo to qi.yang@polimi.it
Originally Posted by bjavila1409 View Post
more files attached
Hi, I am also focusing on this part, did you solve the problem?
qi.yang@polimi.it is offline   Reply With Quote
pimplefoam, sigfpe, snappyhexmesh
DynamicMesh for Fish Motion ShinGS OpenFOAM Running, Solving & CFD 1 February 13, 2023 03:11
UDF for simulating the suction feeding in a fish moh.hefny ANSYS 0 September 9, 2019 16:23
fish dolphin tuna help yang FLUENT 0 November 9, 2010 04:10
How to solve problem about fish swimming and other FSI luckyluke OpenFOAM Running, Solving & CFD 1 September 7, 2005 23:01
Fish Kick Bob Gillett Main CFD Forum 8 September 17, 1999 15:36
