Velocity is zero at the impeller | centrifugal pump |
Zeinab Abosedaira
Rep Power: 4 ![]() |
Hello All, I have run a full flow for a centrifugal pump and got the results. The pressure contours are so good as shown below. However, the velocity contours show zero velocity all over the pump. When I used Slice on ParaView, I found that the velocity has values on the impeller surface as I go through the depth which means that it's not zero all over the pump. What's interesting is that the pressure values are correct. I can't figure out why this is happening. My concern is that I am following a tutorial and the velocity contours are normal in his example. Any guess why this might be happening?
pressure.png Pressure contours of my simulation. velocity.png veolcity_tutorial.PNG velocity contours of my simulation, and velocity contours of the tutorial. slicevelocity.png Velocity Contours of the slice The tutorial I am following : HTML Code:
https://www.youtube.com/watch?v=MwgnOdizuG8&list=PLkKD7eCr9mpxhNAJFAU9NjKrECmcVsD3D&index=9 |
Why am I getting negative pressure head of the Centrifugal Pump through CFD? | raza48919 | FLUENT | 6 | April 26, 2023 14:11 |
[TurboGrid] How to best model centrifugal pump impeller and suction domains using TurboGrid | jgross | ANSYS Meshing & Geometry | 1 | December 28, 2021 17:10 |
How to find centrifugal pump CAD geometry with experimental results for benchmarking? | jgross | Main CFD Forum | 1 | October 18, 2021 12:47 |
problem for centrifugal pump transient simulation | renyun0511 | OpenFOAM Running, Solving & CFD | 8 | January 15, 2014 04:55 |
Radial velocity and tangential velocity on centrifugal fan, | johnnyp | FLUENT | 2 | May 24, 2013 07:10 |
