July 12, 2022, 03:43 |
How to create a new patch from an STL file ?
Rep Power: 4 |
Hi foamers,
I have been struggling to extract a surface as a patch in an STL file in snappyHexMesh. I explain myself, I am studying a breakwater and I want to compute the force in specific locations in the crownwall which I import as an STL file (crownwall.stl). I am using the following code to compute the forces and I need to indicate a patch for the pressure integration : Code:
force1 { type forces ; functionObjectLibs ( "libforces.so" ); patches (SurfaceOfInterest); rho rhoInf; rhoInf 1; CofR (523.5 15 30.693); writeControl timeStep; writeInterval 1; pName p; UName U; log true; Iif so I don't know how to use TopoSet, is there a template/model I can use as a basis ? I have attached the picture of the crownwall with the pink surfaces I want to create to use as a patch for the forces. It's just two squares. Thanks! |
July 12, 2022, 04:32 |
Yann
Rep Power: 27 |
Just linking the original post, as it is usually not a good idea to duplicate threads: How to create a new patch in an STL file ? Regards, Yann |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 36 | July 16, 2024 04:52 |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 15:30 |
steadyUniversalMRFFoam Tutorial fails in MixingPlane | HenrikJohansson | OpenFOAM Bugs | 0 | February 14, 2019 05:48 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 11:59 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 06:18 |
