July 11, 2022, 20:35 |
Fully developed turbulent flow
Rep Power: 4 |
Hello
I am running a simulation to get fully developed flow profile to use it in another simulation. The geometry is a rectangular duct (6x9x100)mm with top and bottom walls, side walls symmetric, inlet, and outlet. I am using simpleFoam (modified pitzdaily case) with realizableKE RAS model. I calculated entry length and get around 70mm, so, I ran the simulation with 100mm long duct. But when I ran a simulation with 500mm as length I got different peak velocity of fully developed flow. This is surprising because once the flow is developed, the velocity shouldn't rise/drop. So, to further investigate I ran a simulation of Reynolds number 500 case (velocity - 0.069674m/s) with laminar and turbulent models. Both have different peak velocities. (laminar ~0.1 turbulent ~0.091) Can someone please enlighten me with the theoretical understanding I am lacking? It would be a great pleasure. I am attaching the case to recreate. case - flowDevelop_500_2.zip Best regards |
fully devloped profile, turbulence and laminar |
1-D Fully Developed Turbulent Pipe flow | RruffPaw | Main CFD Forum | 7 | January 17, 2020 07:03 |
Fully developed flow and convergance | soumitra2102 | Main CFD Forum | 3 | September 11, 2019 10:50 |
3D pipe flow - Using UDF's to define fully developed turbulent flow on the inlet | Taz-CFD | CFD Freelancers | 1 | February 21, 2016 12:12 |
Fully developed flow in Star-cd | SMM | STAR-CD | 3 | September 9, 2011 16:54 |
Fully Developed Flow in Star-cd | SMM | STAR-CD | 0 | September 5, 2011 23:08 |
