neumann BC between two adjacent meshes
Old   July 10, 2022, 16:37
Default neumann BC between two adjacent meshes
celestial is on a distinguished road
Hi
I am looking at the include file solveEnergy.H of the conjugateHeatFoam solver where the temperature for a fluid mesh adjacent to a solid mesh is to be solved using the diffusion equation. The code creates one
global matrix equation Ax =b encompassing both meshes
and my BC at their interface is
k1 * grad T1 = k2 * grad T2
So obviously that BC has to be part of the overall matrix equation
But I can't find that BC listed anywhere under the FvPatchFields subfolders
Any ideas as to how I should proceed ?
Regards to all
celestial is offline   Reply With Quote
Old   July 14, 2022, 17:44
I forgot to mention that this thread is only meaningful to those familiar with foam-extend.
Even with only one mesh to work with, the next level of difficulty after Dirichlet and Neumann BCs is the Robin BC. Now mixed BC is not a bona fide general Robin BC but you cast it into such a form because luckily there is no check for bounds 0<f<1 . Although, if you are interested in non-uniform coefficients, you have no choice but to use the groovyBC version of mixed BC.
Now, since my last post, I could not find anything more sophisticated than that mixed BC. There does not seem to be any readily available function to modify the matrix coefficients when considering the conductivity flow BC at the interface between 2 meshes:
I don t know how hard it is to implement.
For the Poisson equation instead of the diffusion equation, minimizing its functional shows that the BC is implicitly part of the finite element method solution. You don t need to add it. ( e.g. see software Elmer)
Old   July 15, 2022, 15:55
To make it simpler, I would be happy to discretize all these BCs as
Xp = e * Xc + f
for one mesh where X is a scalar field and Xp is its value at the patch and Xc is its value at the center of the cell with that patch as one of the surfaces enclosing that cell.
For the solving of
AX = b
I would like to know where that matrix A and vector b are located in the code and also the coordinates (i,j) of matrix A where the coefficient e will be stored
and thus the coordinate i of vector b where coefficient f will be stored
(which gives the coordinate (i,i) in A where the coefficient 1 of Xp is stored)
Of course if there are two meshes and the patch is at their interface, the matrix A encompassing both meshes will now be larger.
Moreover my BC now becomes
Xp = e * Xc + f + g * Xn
where Xn represents the same thing as Xc but for the other mesh and I will also need to know the coordinates (i,j') of matrix A where the coefficient g will be stored.
It could very well be that only the experts who wrote the code can answer that query.
Have a nice weekend to all
Old   August 10, 2022, 16:27
Default Very disappointing
To sum up, unless somebody proves me wrong, OpenFOAM was never designed to modify the coefficients of the matrix equation to be solved even for so standard a boundary condition as
k1*grad T1 = k2*grad T2 + S
(adjacent meshes with different heat conductivities and a source term S at their interface. I am interested in k1, k2, S each a function of space and time but the BC does not even exist for constant k1, k2 and S )
I fear that adding this feature may require considerable programming effort.
Old   August 11, 2022, 04:00
Domenico Lahaye
dlahaye is on a distinguished road
Not sure about S <> 0.
In case that S = 0 , k1 grad T1 = k2 grad T2 is part of the formulation that e.g. chtMultiRegionFoam solves. Older versions of chtMultiRegionFoam iterate between subdomains. Newer version implement a monolithic solver.
For S<>0, I would look into line sources first.
dlahaye is offline   Reply With Quote
Old   August 12, 2022, 17:58
Thank you very much Domenico but I think the monolithic solver you mention is actually
conjugateHeatFoam
available in foam-extend.
However, it is not enough to use patch regionCoupling in a dictionary. I will need to modify the source code - probably in regionCouplingFvPatchField.C.
This will be hard as one has to first understand the source code and the fact that there are hardly any comments accompanying the code for sure does not make the task easier ( I was taught more than 3 decades ago to always add relevant comments to code).
Old   August 16, 2022, 07:18
Domenico Lahaye
Dear Celestial,
Thank you you for pointing me to conjugateHeatFoam.
I imagine that this coupled solver (at https://sourceforge.net/p/foam-exten.../solveEnergy.H for future reference) does away with the need of implementing the interface conditions. This would similar to the Elmer solution and what we do for finite elements.
Remains the question what you want to implement.
Is it your wish to implement a line source of the solid/gas interface? Are you happy to diffuse the support of the source over a few cells to start from? Can you employ fvOptions to this end?
Cheers. Domenico.
Old   August 18, 2022, 18:50
I am actually solving am electrostatics problem - so the Poisson equation over 2 meshes with the BC
e1 * grad E1 = e2 * grad E2 + Surface Charge
at the interface where E stands for electric field and e for electrical permittivity.
I was justing recasting the same equation in a static mechanical engineering context so that most CFD folks would be very likely familiar with heat flow.
It is true that in Elmer you just specify the surface charge and the user does not need to write any source code for the above BC since it is already built-in.
Looking at solveEnergy.H though, I can see it does not implement anything about BCs.
Which means I will probably have to write it as I alluded to in my last post.
I am not very familiar with fvOptions but anyhow I don't want to shift the BC to inside one the mesh and close to the interface like you were suggesting.
Preserve meshes in Fluent parametric run hwerner2014 FLUENT 2 February 28, 2022 17:29
JOB ABORT invoked by rank 17 ltl CONVERGE 3 January 25, 2021 16:05
Mapping (interpolation) between two meshes Ebrahim OpenFOAM Programming & Development 2 June 15, 2020 14:31
How can I put the data of adpated meshes on the original unadapted meshes? xh110120 FLUENT 2 March 11, 2016 03:00
creating CHT case from two adjacent nonconformal meshes skuznet OpenFOAM Pre-Processing 0 June 9, 2014 16:33
