Gurjot Ahuja
Rep Power: 4 ![]() |
I am simulating a diamond airfoil at supersonic flow at Mach 3. I am using rhoCentralFoam as a solver and k-w SST turbulence model to solve this case. When I use velocity boundary condition as "slip" for the airfoil boundary, my run is successful without any problems, but when I change the BC to "noSlip". I am getting a "Negative Initial Temperature T0" error and the run crashes. I have also tried to limit the temperature using fvOptions, but it's not working. I have also checked by refining the mesh, but still, the problem exists. Please help me. Other boundary conditions for airfoil are as follows: p - type zeroGradient T - type zeroGradient alphat - type compressible::alphatWallFunction, value uniform 8.88e-9 epsilon - type epsilonWallFunction, value uniform 365627.58 k - type kqRWallFunction, value uniform 901.31 nut - type nutkWallFunction, value uniform 0.199 omega - type omegaWallFunction, value uniform 4507.4 Last edited by tum-student; July 10, 2022 at 09:53. |
Rep Power: 2 ![]() |
Have you had any luck in solving this issue? I keep getting those negative Temperature errors, however, after a few tenths of a second in the simulation. Thank you. |
airfoil, negative temperature, noslip, rhocentralfoam, viscous flow |
Openfoam Turbulent Car Simulation | meganrw | OpenFOAM Running, Solving & CFD | 0 | July 5, 2021 15:50 |
Wall Conditions : fixedValue or noSlip | Magistrane | OpenFOAM Running, Solving & CFD | 4 | September 28, 2020 06:55 |
ACMI rotating zone: which frame is used for fixedValue, noSlip, movingWallVelocity? | zommuter | OpenFOAM Running, Solving & CFD | 0 | September 2, 2020 03:13 |
Problem with boundary layer - noSlip condition not being respected - OpenFOAM | heitorvitorc | OpenFOAM Post-Processing | 1 | August 14, 2019 05:14 |
multiphaseEulerFoam/tank discharge | ves | OpenFOAM Running, Solving & CFD | 8 | December 31, 2017 14:59 |
