July 3, 2022, 02:18 |
Water Jet inside water(single phase)
Farzad Faraji
Rep Power: 7 |
Dear all
I want to simulate a water jet inside a water domain at T=25 Celsius. I have two problems(first one is not important at this time); 1- I use fvoptions to generate Ubar=jet velocity Code:
momentumSource { type meanVelocityForce; active on; //on; meanVelocityForceCoeffs { timeStart 0.; duration 1000.; selectionMode cellZone; cellZone CIRCLEinY; fields (U); Ubar (0.0 0.64 0.0) relaxation 0.1; } } 2- When I use water characteristics at T=25(nu = 8.917e-7) jet does not dissipates and very strongly goes to the free surface(see figure for Ubar=0.64 which gives 1.2). Then when I use "Ubar = 0.3458" which give Unozzle = 0.64 it is still very strong(see second Figure). why my results are totally different from experiment? 3- There is only one possibility which is not adding the fluctuations at the nozzle exit which makes the jet very strong and coherent. My question is that how can I add fluctuations when I use fvoption to generate jet? Thanks, Farzad |
fluctuations, fvoption, openfoam, water jet |
Water circuit inside air enclosure | captainpimienta | FLUENT | 2 | January 4, 2021 02:54 |
water velocity and water velocity in stationary frame of a water jet | zehab | CFX | 0 | May 11, 2020 03:17 |
coaxial jet flow into an open water tank | sreesha | FLUENT | 0 | January 26, 2017 14:29 |
Please**need help on Tow phase flow ( water & steam water) analysis** | ali_kntu | CFX | 2 | December 19, 2013 16:15 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
