June 30, 2022, 10:59 |
Continue a simulation with modifications
Rep Power: 6 |
Hello everyone,
I recently found that it is possible to continue a stopped simulation in OpenFOAM, starting from the last timestep generated : Can we restart the simulation from a different time in OpenFoam I would like to continue my simulation, but this time, with some modifications. For exemple, you have a pipe and you want to model the wind behaviour based on the section profile in the last part of the pipe. The behaviour of the wind in the first part of the pipe will always remain the same, and running multiple times this beginning of the simulation (for each end of the pipe) is really a waste of time. In FEM softwares, you are usually able to run the first part and set it as a calculation base, and then run all the different scenarios starting from this base (you don't need to re-run the base eash time). This is how it works in LS-DYNA for exemple : https://ftp.lstc.com/anonymous/outgo...ay/restart.pdf Does anyone know if it is possible on OpenFOAM to run a simulation for some time, stop it, make geometry modifications, and continue the simulation ? I tried it but I end up with geometry errors. Thank You for your help, Guillaume. |
July 5, 2022, 12:47 |
Lorenzo
Rep Power: 6 |
When I needed to run a case with a different mesh resolution or with a longer domain, I used mapFields to set the initial conditions as the final step of a "base-case" (working with OpenFOAM v-2012 by ESIgroup). You may have a look on that, I am not sure if this would cause problems at the beginning in terms of stability. https://www.openfoam.com/documentati...mapFields.html Regards, Lorenzo |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 03:28 |
can not continue running simulation with trn file | mao | CFX | 5 | September 23, 2016 11:31 |
Short shot simulation problems in die casting simulation correlation with test | yanhua.li | FLOW-3D | 12 | August 3, 2016 03:21 |
command TUI / Scheme for stop and continue calculate | rayolau | FLUENT | 1 | May 13, 2013 11:20 |
2D CFD code using SIMPLE algorithm | bfan | Main CFD Forum | 3 | June 22, 2002 23:01 |
