Whole domain movement rigid body with overset
Old   June 30, 2022, 06:52
Default Whole domain movement rigid body with overset
Paul Jakob
pj_design is on a distinguished road
Dear Foamers,
I am trying to simulate a turning circle manoeuvre of a jet boat with v2112. To reduce the number of cells the whole domain has to move with the hull. Attached you will find a reference picture found in the Journal of Marine Science and Technology (2020) 25:769–786 "Numerical simulation about the manoeuvre of trimaran and asymmetric twin hull with hull attitude taken into account by OpenFOAM".
The case I am trying to simulate is similar to the tutorial case multiphase/overInterDyMFoam/rigidBodyHull. The tutorial case uses a solid body motion "drivenLinearMotion" for the domain to follow the motion of the rigid body (hull). The problem is, that "drivenLinearMotion" can only handle linear motions. A turning circle manoeuvre requires rotational movement of the domain.
To my understanding it should be possible to handle the case with rigid body motion solver alone. Therefore the whole domain (parent) is treated as a rigid body and the hull is the child. So if I apply an external force on the hull, the whole rigid body domain should move together with the hull (see the dynamicMeshDict attached).
My setup works for the overset and for all the refinement zones of the domain except for the domain boundaries (inlet, outlet, atmosphere, bottom) which remain static (see the attached picture). So the domain mesh is deformed at the boundaries instead, and the rigid body motion is not applied.
Thank you for your help,
Paul
pj_design is offline   Reply With Quote
Old   March 23, 2024, 09:52
huazhongdk@gmail.com is on a distinguished road
Hi pj_design,
I have added a "driven3DofMotion" to realize the function you mentioned. If you are interested, you can find it on my github page. https://github.com/balabibo/An-OpenF...imulations.git. You should add that file and replace the "rigidBodyMeshMotion.C & H" to use it. The dynamicMeshDict is just similar to that one when you use the "drivenLinearMotion".
huazhongdk@gmail.com is offline   Reply With Quote
domain movement, drivenlinearmotion, overinterdymfoam, overset, rigid body
Rigid body + remeshing error in redefining the rigid body updated-initial conditions Pat84 CFX 27 August 30, 2022 12:25
Tracking movement of an axial oscillating rigid body lreid OpenFOAM Pre-Processing 0 January 19, 2021 12:04
Fluid Domain moving with Rigid body Lloyd Sullivan CFX 3 August 17, 2018 10:58
Rigid body in creeping flow - COMSOL MultiPhy CFD Freelancers 1 June 8, 2017 02:38
Rigid body - pivoting about a fixed point Catenary CFX 0 April 26, 2012 03:07
