Time-varying massFlowRate
Old   June 20, 2022, 10:42
Question Time-varying massFlowRate
Chris
Chris T is on a distinguished road
Hi all,
I'm trying to run a case with with chtMultiregionFoam. I am using the following as the b.c. for my inlet velocity.
inlet
        type            flowRateInletVelocity;
        value           uniform ( 0 0 0 );
        massFlowRate    1.22;
        extrapolateProfile yes;
        rho             rho;
        rhoInlet        1800;
I want to try and implement a time-varying velocity to gradually ramp up the inlet velocity. This is mainly to see if it helps to avoid the divergence I experience in the first few time-steps.
I want to implement something analogous to this
type
uniformFixedValue;
uniformValue table ((0 0) (10 5) (999999999 5));
but I'm not sure how to achieve this. I tried
inlet
        massFlowRate    uniformValue table ((0 0) (10 5) (999999999 5));
        rho             rho;
        rhoInlet        1800;
but I get the error
[4] --> FOAM FATAL ERROR:
[4] Cannot find file "points" in directory "cavity/polyMesh" in times "0" down to constant
I found this older post time-varying flowRateInletVelocity bc for OF5 but it is not much helpful.
Any solution to this problem or suggestions to alternatives will be appreciated.
Best,
Chris
Edit: Btw I'm using openfoam v9.
Chris T is offline   Reply With Quote
chtmultiregionfoam, inlet velocity, time-varying b.c.
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 42 May 8, 2024 00:17
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
