Floating point exception error when rotate the geometry
Old   June 20, 2022, 06:48
Default Floating point exception error when rotate the geometry
Tony Zhang
zyfsoton is on a distinguished road
Hi all,
I am simulating the hull with different drift angles. When the drift angle is applied, the error of floating-point exception is found. I think the error comes from the mesh problem. I am using the openfoam7's interFoam solver and the error happens when I try to use the potentialFoam to initialize the case. Also, if the potentialFoam is skipped, the error also happens when run the interFoam:
The error reported in terminal when run potentialFoam:
Build  : 7
Exec   : potentialFoam -withFunctionObjects -parallel
Date   : Jun 18 2022
Time   : 18:18:49
Host   : "Tony"
PID    : 24123
I/O    : uncollated
Case   : /home/OpenFOAM/-7/run/kcs-5d-5r-vof/VOF
nProcs : 80
Slaves :
79
Pstream initialized with:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
    commsType          : nonBlocking
    polling iterations : 0
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading velocity field U
Constructing pressure field p
Constructing velocity potential field Phi
No MRF models present
Calculating potential flow
	createExtraFields : Adding field alpha.water to database.
forces totForce:
    Not including porosity effects
forces hull_Force:
forces rudder_Force:
[24] #0  Foam::error::printStack(Foam::Ostream&)[27] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
[24] #1  Foam::sigFpe::sigHandler(int) at ??:?
[27] #1  Foam::sigFpe::sigHandler(int) at ??:?
[27] #2  ? at ??:?
[24] #2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
[27] #3  Foam::DICPreconditioner::calcReciprocalD(Foam::Field<double>&, Foam::lduMatrix const&) in "/lib/x86_64-linux-gnu/libc.so.6"
[24] #3  Foam::DICPreconditioner::calcReciprocalD(Foam::Field<double>&, Foam::lduMatrix const&) at ??:?
[24] #4  Foam::DICSmoother::DICSmoother(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&) at ??:?
[27] #4  Foam::DICSmoother::DICSmoother(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&) at ??:?
[24] #5  Foam::lduMatrix::smoother::addsymMatrixConstructorToTable<Foam::DICSmoother>::New(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&) at ??:?
[27] #5  Foam::lduMatrix::smoother::addsymMatrixConstructorToTable<Foam::DICSmoother>::New(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&) at ??:?
[24] #6  Foam::lduMatrix::smoother::New(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::dictionary const&) at ??:?
[24] #7  Foam::GAMGSolver::initVcycle(Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::lduMatrix::smoother>&, Foam::Field<double>&, Foam::Field<double>&) const at ??:?
[27] #6  Foam::lduMatrix::smoother::New(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::dictionary const&) at ??:?
[24] #8  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
[27] #7  Foam::GAMGSolver::initVcycle(Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::lduMatrix::smoother>&, Foam::Field<double>&, Foam::Field<double>&) const at ??:?
[24] #9  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
[27] #8  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
[27] #9  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
[24] #10  Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
[27] #10   in "/home/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/bin/potentialFoam"
[24] #11  Foam::fvMatrix<double>::solve()Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/bin/potentialFoam"
[24] #12   in "/home/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/bin/potentialFoam"
[27] #11  ?Foam::fvMatrix<double>::solve() in "/home/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/bin/potentialFoam"
[24] #13  __libc_start_main in "/home//OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/bin/potentialFoam"
[27] #12   in "/lib/x86_64-linux-gnu/libc.so.6"
[24] #14  ?? in "/home/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/bin/potentialFoam"
[27] #13  __libc_start_main[Tonnnnnnnnnnny:24183] *** Process received signal ***
[Tonnnnnnnnnnny:24183] Signal: Floating point exception (8)
[Tonnnnnnnnnnny:24183] Signal code:  (-6)
[Tonnnnnnnnnnny:24183] Failing at address: 0x3e800005e77
[Tonnnnnnnnnnny:24183] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef10)[0x7f92ea224f10]
[Tonnnnnnnnnnny:24183] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7f92ea224e87]
[Tonnnnnnnnnnny:24183] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef10)[0x7f92ea224f10]
[Tonnnnnnnnnnny:24183] [ 3] /home//OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam17DICPreconditioner15calcReciprocalDERNS_5FieldIdEERKNS_9lduMatrixE+0x107)[0x7f92eb61ba97]
[Tonnnnnnnnnnny:24183] [ 4] /home//OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam11DICSmootherC1ERKNS_4wordERKNS_9lduMatrixERKNS_10FieldFieldINS_5FieldEdEESB_RKNS_8UPtrListIKNS_17lduInterfaceFieldEEE+0x49)[0x7f92eb6171f9]
[Tonnnnnnnnnnny:24183] [ 5] /home//OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam9lduMatrix8smoother30addsymMatrixConstructorToTableINS_11DICSmootherEE3NewERKNS_4wordERKS0_RKNS_10FieldFieldINS_5FieldEdEESE_RKNS_8UPtrListIKNS_17lduInterfaceFieldEEE+0x48)[0x7f92eb6173a8]
[Tonnnnnnnnnnny:24183] [ 6] /home//OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam9lduMatrix8smoother3NewERKNS_4wordERKS0_RKNS_10FieldFieldINS_5FieldEdEESB_RKNS_8UPtrListIKNS_17lduInterfaceFieldEEERKNS_10dictionaryE+0x234)[0x7f92eb605f44]
[Tonnnnnnnnnnny:24183] [ 7] /home/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver10initVcycleERNS_7PtrListINS_5FieldIdEEEES5_RNS1_INS_9lduMatrix8smootherEEERS3_SA_+0xb1)[0x7f92eb62fbe1]
[Tonnnnnnnnnnny:24183] [ 8] /homeOpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5FieldIdEERKS2_h+0x41e)[0x7f92eb63547e]
[Tonnnnnnnnnnny:24183] [ 9] /home/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x17d)[0x7f92ed51fa3d]
[Tonnnnnnnnnnny:24183] [10] potentialFoam(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x15b)[0x55dba614c2ab]
[Tonnnnnnnnnnny:24183] [11] potentialFoam(_ZN4Foam8fvMatrixIdE5solveEv+0x152)[0x55dba614c672]
[Tonnnnnnnnnnny:24183] [12] potentialFoam(+0x2d21a)[0x55dba610621a]
[Tonnnnnnnnnnny:24183] [13] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f92ea207c87]
[Tonnnnnnnnnnny:24183] [14] potentialFoam(+0x2e66a)[0x55dba610766a]
[Tonnnnnnnnnnny:24183] *** End of error message ***
[27] #14  ?[Tonnnnnnnnnnny:24192] *** Process received signal ***
[Tonnnnnnnnnnny:24192] Signal: Floating point exception (8)
[Tonnnnnnnnnnny:24192] Signal code:  (-6)
[Tonnnnnnnnnnny:24192] Failing at address: 0x3e800005e80
[Tonnnnnnnnnnny:24192] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef10)[0x7eff726b0f10]
[Tonnnnnnnnnnny:24192] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7eff726b0e87]
[Tonnnnnnnnnnny:24192] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef10)[0x7eff726b0f10]
[Tonnnnnnnnnnny:24192] [ 3] /homeOpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam17DICPreconditioner15calcReciprocalDERNS_5FieldIdEERKNS_9lduMatrixE+0x107)[0x7eff73aa7a97]
[Tonnnnnnnnnnny:24192] [ 4] /home//OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam11DICSmootherC1ERKNS_4wordERKNS_9lduMatrixERKNS_10FieldFieldINS_5FieldEdEESB_RKNS_8UPtrListIKNS_17lduInterfaceFieldEEE+0x49)[0x7eff73aa31f9]
[Tonnnnnnnnnnny:24192] [ 5] /home/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam9lduMatrix8smoother30addsymMatrixConstructorToTableINS_11DICSmootherEE3NewERKNS_4wordERKS0_RKNS_10FieldFieldINS_5FieldEdEESE_RKNS_8UPtrListIKNS_17lduInterfaceFieldEEE+0x48)[0x7eff73aa33a8]
[Tonnnnnnnnnnny:24192] [ 6] /home/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam9lduMatrix8smoother3NewERKNS_4wordERKS0_RKNS_10FieldFieldINS_5FieldEdEESB_RKNS_8UPtrListIKNS_17lduInterfaceFieldEEERKNS_10dictionaryE+0x234)[0x7eff73a91f44]
[Tonnnnnnnnnnny:24192] [ 7] /home/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver10initVcycleERNS_7PtrListINS_5FieldIdEEEES5_RNS1_INS_9lduMatrix8smootherEEERS3_SA_+0xb1)[0x7eff73abbbe1]
[Tonnnnnnnnnnny:24192] [ 8] /home/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5FieldIdEERKS2_h+0x41e)[0x7eff73ac147e]
[Tonnnnnnnnnnny:24192] [ 9] /home/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x17d)[0x7eff759aba3d]
[Tonnnnnnnnnnny:24192] [10] potentialFoam(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x15b)[0x55bd60b762ab]
[Tonnnnnnnnnnny:24192] [11] potentialFoam(_ZN4Foam8fvMatrixIdE5solveEv+0x152)[0x55bd60b76672]
[Tonnnnnnnnnnny:24192] [12] potentialFoam(+0x2d21a)[0x55bd60b3021a]
[Tonnnnnnnnnnny:24192] [13] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7eff72693c87]
[Tonnnnnnnnnnny:24192] [14] potentialFoam(+0x2e66a)[0x55bd60b3166a]
[Tonnnnnnnnnnny:24192] *** End of error message ***
mpirun noticed that process rank 24 with PID 0 on node Tonnnnnnnnnnny exited on signal 8 (Floating point exception).
The error when run the interFoam
Build  : 7
Exec   : interFoam
Date   : Jun 18 2022
Time   : 18:19:41
Host   : "Tony"
PID    : 24465
I/O    : uncollated
nProcs : 1
Create time
Selecting dynamicFvMesh staticFvMesh
PIMPLE: No convergence criteria found
PIMPLE: Operating solver in transient mode with 1 outer corrector
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kOmegaSST
Selecting patchDistMethod meshWave
RAS
    RASModel        kOmegaSST;
    turbulence      on;
    printCoeffs     on;
    alphaK1         0.85;
    alphaK2         1;
    alphaOmega1     0.5;
    alphaOmega2     0.856;
    gamma1          0.555556;
    gamma2          0.44;
    beta1           0.075;
    beta2           0.0828;
    betaStar        0.09;
    a1              0.31;
    b1              1;
    c1              10;
    F3              false;
Reading g
Reading hRef
Calculating field g.h
No finite volume options present
#10  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/bin/interFoam"
#11  Foam::fvMatrix<double>::solve() in "/home/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/bin/interFoam"
#12  ? in "/home/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/bin/interFoam"
#13  ? in "/home/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/bin/interFoam"
#14  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#15  ? in "/home/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/bin/interFoam"
Floating point exception (core dumped)
The checkMesh output is as follows:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
Build  : 7
Exec   : checkMesh
Date   : Jun 20 2022
Time   : 10:13:08
Host   : "Tonnnnnnnnnnny"
PID    : 20146
I/O    : uncollated
Case   : /home/OpenFOAM7/run/kcs-5d-5r-vof/VOF
nProcs : 1
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    faces:            8916909
    internal faces:   8857243
    cells:            2906353
    faces per cell:   6.11562
    boundary patches: 8
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     2707592
    prisms:        6247
    wedges:        0
    pyramids:      0
    tet wedges:    101
    tetrahedra:    0
    polyhedra:     192413
    Breakdown of polyhedra by number of faces:
        faces   number of cells
            4   2618
            5   2265
            6   10700
            7   89913
            8   11424
            9   71683
           10   761
           11   359
           12   2253
           13   46
           14   46
           15   336
           16   2
           17   1
           18   6
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
   *Number of regions: 11
    The mesh has multiple regions which are not connected by any face.
  <<Writing region information to "0/cellToRegion"
  <<Writing region 0 with 2906343 cells to cellSet region0
  <<Writing region 1 with 1 cells to cellSet region1
  <<Writing region 2 with 1 cells to cellSet region2
  <<Writing region 3 with 1 cells to cellSet region3
  <<Writing region 4 with 1 cells to cellSet region4
  <<Writing region 5 with 1 cells to cellSet region5
  <<Writing region 6 with 1 cells to cellSet region6
  <<Writing region 7 with 1 cells to cellSet region7
  <<Writing region 8 with 1 cells to cellSet region8
  <<Writing region 9 with 1 cells to cellSet region9
  <<Writing region 10 with 1 cells to cellSet region10
Checking patch topology for multiply connected surfaces...
                   Patch    Faces   Points                  Surface topology
              atmosphere     3952     4115  ok (non-closed singly connected)
                   inlet     1280     1353  ok (non-closed singly connected)
                  outlet      800      861  ok (non-closed singly connected)
                  bottom      940     1008  ok (non-closed singly connected)
                    side      800      861  ok (non-closed singly connected)
                midPlane      800      861  ok (non-closed singly connected)
                    hull    33940    37082  ok (non-closed singly connected)
                  rudder    17154    17535  ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-14 -21 -7) (28 21 3.5)
    Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
    Mesh has 3 solution (non-empty) directions (1 1 1)
    Boundary openness (2.75452e-17 -5.16445e-17 9.76081e-16) OK.
    Max cell openness = 1.87665e-15 OK.
    Max aspect ratio = 900.091 OK.
    Minimum face area = 2.53816e-08. Maximum face area = 4.41478.  Face area magnitudes OK.
    Min volume = 4.8239e-13. Max volume = 4.91023.  Total volume = 18519.1.  Cell volumes OK.
    Mesh non-orthogonality Max: 69.8864 average: 6.38148
    Non-orthogonality check OK.
    Face pyramids OK.
 ***Max skewness = 7.84018, 21 highly skew faces detected which may impair the quality of the results
  <<Writing 21 skew faces to set skewFaces
    Coupled point location match (average 0) OK.
Failed 1 mesh checks.
End
Even the skewness error is found, but I don't think it is the source of error since the case without rotation can run smoothly even there is also skewness error as well.
Please let me know if you have any idea how to resolve this error, any hint will be appreciated!
Many thanks,
Tony
zyfsoton is offline   Reply With Quote
Old   June 20, 2022, 06:49
Tony Zhang
I suspect the error is because snappyHexMesh, the file of SHM is attached for reference:
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap            true;
addLayers       true;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
    KCS_modelScale.stl.gz
        type triSurfaceMesh;
        name hull;
        patchInfo
            type wall;
    kcs_rudder_ModelScale_5.stl
        name rudder;
        patchInfo
            type wall;
    /*appendage_stl_name_1
        name appendage_name_1;
        patchInfo
            type wall;
    /*appendage_stl_name_2
        name appendage_name_2;
        patchInfo
            type wall;
    /*appendage_stl_name_3
        name appendage_name_3;
        patchInfo
            type wall;
    /*appendage_stl_name_4
        name appendage_name_4;
        patchInfo
            type wall;
    /*appendage_stl_name_5
        name appendage_name_5;
        patchInfo
            type wall;
    /*appendage_stl_name_6
        name appendage_name_6;
        patchInfo
            type wall;
    /*appendage_stl_name_7
        name appendage_name_7;
        patchInfo
            type wall;
    /*appendage_stl_name_8
        name appendage_name_8;
        patchInfo
            type wall;
    /*appendage_stl_name_9
        name appendage_name_9;
        patchInfo
            type wall;
    /*wakeBox
        type searchableBox;
        min (wakebox_mix wakebox_miy wakebox_miz);
        max (wakebox_max wakebox_may wakebox_maz);
    /*bowBox
        type searchableBox;
        min (bowbox_mix bowbox_miy bowbox_miz);
        max (bowbox_max bowbox_may bowbox_maz);
    /*bigBox
        type searchableBox;
        min (bigbox_mix bigbox_miy bigbox_miz);
        max (bigbox_max bigbox_may bigbox_maz);
    /*propTube
        type searchableCylinder;
	point1 (prop_mix prop_miy prop_miz);
	point2 (prop_max prop_may prop_maz);
	radius prop_rad;
// Settings for the castellatedMesh generation.
castellatedMeshControls
    // Refinement parameters
    // If local number of cells is >= maxLocalCells on any processor
    // switches from from refinement followed by balancing
    // (current method) to (weighted) balancing before refinement.
    maxLocalCells 1000000000;
    // Overall cell limit (approximately). Refinement will stop immediately
    // upon reaching this number so a refinement level might not complete.
    // Note that this is the number of cells before removing the part which
    // is not 'visible' from the keepPoint. The final number of cells might
    // actually be a lot less.
    maxGlobalCells 200000000;
    // The surface refinement loop might spend lots of iterations refining just a
    // few cells. This setting will cause refinement to stop if <= minimumRefine
    // are selected for refinement. Note: it will at least do one iteration
    // (unless the number of cells to refine is 0)
    minRefinementCells 0;
    // Number of buffer layers between different levels.
    // 1 means normal 2:1 refinement restriction, larger means slower
    // refinement.
    nCellsBetweenLevels 4;
    // Explicit feature edge refinement
    // Specifies a level for any cell intersected by its edges.
    // This is a featureEdgeMesh, read from constant/triSurface for now.
    features
             file "hull.eMesh";
             level 0;
             file "rudder.eMesh";
             level 3;
             file "appendage_name_1.eMesh";
             level r_alevelm_1;
             file "appendage_name_2.eMesh";
             level r_alevelm_2;
             file "appendage_name_3.eMesh";
             level r_alevelm_3;
             file "appendage_name_4.eMesh";
             level r_alevelm_4;
             file "appendage_name_5.eMesh";
             level r_alevelm_5;
             file "appendage_name_6.eMesh";
             level r_alevelm_6;
             file "appendage_name_7.eMesh";
             level r_alevelm_7;
             file "appendage_name_8.eMesh";
             level r_alevelm_8;
             file "appendage_name_9.eMesh";
             level r_alevelm_9;
    // Surface based refinement
    // Specifies two levels for every surface. The first is the minimum level,
    // every cell intersecting a surface gets refined up to the minimum level.
    // The second level is the maximum level. Cells that 'see' multiple
    // intersections where the intersections make an
    // angle > resolveFeatureAngle get refined up to the maximum level.
    refinementSurfaces
        hull
            // Surface-wise min and max refinement level
            level (0 0);
        rudder
            level (3 3);
        /*appendage_name_1
            level (r_alevelm_1 r_alevelm_1);
        /*appendage_name_2
            level (r_alevelm_2 r_alevelm_2);
        /*appendage_name_3
            level (r_alevelm_3 r_alevelm_3);
        /*appendage_name_4
            level (r_alevelm_4 r_alevelm_4);
        /*appendage_name_5
            level (r_alevelm_5 r_alevelm_5);
        /*appendage_name_6
            level (r_alevelm_6 r_alevelm_6);
        /*appendage_name_7
            level (r_alevelm_7 r_alevelm_7);
        /*appendage_name_8
            level (r_alevelm_8 r_alevelm_8);
        /*appendage_name_9
            level (r_alevelm_9 r_alevelm_9);
    resolveFeatureAngle 15;
    // Region-wise refinement
    // Specifies refinement level for cells in relation to a surface. One of
    // three modes
    // - distance. 'levels' specifies per distance to the surface the
    //   wanted refinement level. The distances need to be specified in
    //   descending order.
    // - inside. 'levels' is only one entry and only the level is used. All
    //   cells inside the surface get refined up to the level. The surface
    //   needs to be closed for this to be possible.
    // - outside. Same but cells outside.
    refinementRegions
        /*wakeBox
            mode inside;
            levels ((1E15 0));
	/*bowBox
            mode inside;
            levels ((1E15 0));
        /*bigBox
            mode inside;
            levels ((1E15 0));
	/*propTube
            mode inside;
            levels ((1E15 r_levelp));
    // Mesh selection
    // After refinement patches get added for all refinementSurfaces and
    // all cells intersecting the surfaces get put into these patches. The
    // section reachable from the locationInMesh is kept.
    // NOTE: This point should never be on a face, always inside a cell, even
    // after refinement.
    locationInMesh (17.75978400000000000000 21.39908400000000000000 3.87192100000000000000);
    // Whether any faceZones (as specified in the refinementSurfaces)
    // are only on the boundary of corresponding cellZones or also allow
    // free-standing zone faces. Not used if there are no faceZones.
    allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
    //- Number of patch smoothing iterations before finding correspondence
    //  to surface
    nSmoothPatch 3;
    //- Relative distance for points to be attracted by surface feature point
    //  or edge. True distance is this factor times local
    //  maximum edge length.
    //    tolerance 4.0;
    tolerance 1.0;
    //- Number of mesh displacement relaxation iterations.
    nSolveIter 100;
    //- Maximum number of snapping relaxation iterations. Should stop
    //  before upon reaching a correct mesh.
    nRelaxIter 5;
    nFeatureSnapIter 10;
// Settings for the layer addition.
addLayersControls
    // Are the thickness parameters below relative to the undistorted
    // size of the refined cell outside layer (true) or absolute sizes (false).
    relativeSizes false;
    // Per final patch (so not geometry!) the layer information
    layers
        hull
            nSurfaceLayers 28;
	rudder
            nSurfaceLayers 18;
	/*appendage_name_1
            nSurfaceLayers n_alayers_1;
	/*appendage_name_2
            nSurfaceLayers n_alayers_2;
	/*appendage_name_3
            nSurfaceLayers n_alayers_3;
	/*appendage_name_4
            nSurfaceLayers n_alayers_4;
	/*appendage_name_5
            nSurfaceLayers n_alayers_5;
	/*appendage_name_6
            nSurfaceLayers n_alayers_6;
	/*appendage_name_7
            nSurfaceLayers n_alayers_7;
	/*appendage_name_8
            nSurfaceLayers n_alayers_8;
	/*appendage_name_9
            nSurfaceLayers n_alayers_9;
    // Expansion factor for layer mesh
    expansionRatio 1.2;
    // Wanted thickness of final added cell layer. If multiple layers
    // is the thickness of the layer furthest away from the wall.
    // See relativeSizes parameter.
    firstLayerThickness .00002758287143393045;
    // Minimum thickness of cell layer. If for any reason layer
    // cannot be above minThickness do not add layer.
    minThickness .00000005516574286786;
    // If points get not extruded do nGrow layers of connected faces that are
    // also not grown. This helps convergence of the layer addition process
    // close to features.
    // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x)
    nGrow 0;
    // Advanced settings
    // When not to extrude surface. 0 is flat surface, 90 is when two faces
    // are perpendicular
    featureAngle 30;
    // Maximum number of snapping relaxation iterations. Should stop
    nRelaxIter 5;
    // Number of smoothing iterations of surface normals
    nSmoothSurfaceNormals 1;
    // Number of smoothing iterations of interior mesh movement direction
    nSmoothNormals 5;
    // Smooth layer thickness over surface patches
    nSmoothThickness 10;
    // Stop layer growth on highly warped cells
    maxFaceThicknessRatio 0.7;
    // Reduce layer growth where ratio thickness to medial
    // distance is large
    maxThicknessToMedialRatio 0.3;
    // Angle used to pick up medial axis points
    // Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x.
    minMedianAxisAngle 90;
    // Create buffer region for new layer terminations
    nBufferCellsNoExtrude 0;
    // Overall max number of layer addition iterations. The mesher will exit
    // if it reaches this number of iterations; possibly with an illegal
    // mesh.
    nLayerIter 50;
    // Max number of iterations after which relaxed meshQuality controls
    // get used. Up to nRelaxIter it uses the settings in meshQualityControls,
    // after nRelaxIter it uses the values in meshQualityControls::relaxed.
    nRelaxedIter 20;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
    #include "meshQualityDict"
// Advanced
// Flags for optional output
// 0 : only write final meshes
// 1 : write intermediate meshes
// 2 : write volScalarField with cellLevel for postprocessing
// 4 : write current intersections as .obj files
debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1E-6;
Floating Point exception (core dumped) chtMultiRegionFoam ayu12 OpenFOAM Running, Solving & CFD 1 October 12, 2021 12:31
icoFoam floating point exception (8) leizhao512 OpenFOAM Running, Solving & CFD 7 November 1, 2018 12:43
A floating point exception has occurred: floating point exception [Overflow]. starlight STAR-CCM+ 4 May 4, 2016 10:08
A floating point exception - SEM Model yansheng STAR-CCM+ 1 April 4, 2016 05:57
Floating point exception from twoPhaseEulerFoam openfoammaofnepo OpenFOAM Running, Solving & CFD 1 March 19, 2016 14:56
