How to add hydrostatic Pressure to simpleFoam |
Mahmoud
Rep Power: 5 ![]() |
Dear Foamers,
I want to simulate an open channel flow with simpleFoam. U: inlet: FixedValue outlet:zeroGradient P: inlet: zeroGradient outlet: ??? I added the gravity constant in fvOptions. I am wondering how to set the pressure at the outlet to show the effects of the hydrostatic pressure? I set it to zero and it showed all zero as I expected. In another approach, I calculated the hydrostatic pressure in MATLAB and used those values at the outlet, but it did not converge. Any comments and hints would be appreciated. Please note that I do not want to use buoyantBoussinesqSimpleFoam as it solved the temperature equation which takes longer to solve. Also, I just want to use steady-state not transient case and interFoam. Cheers |
Hydrostatic pressure modelling in simpleFOAM | EJohn | OpenFOAM Running, Solving & CFD | 5 | June 10, 2022 14:55 |
Pressure fields in FOAM, p field, total pressure, etc. | Tobi | OpenFOAM Post-Processing | 9 | March 25, 2022 01:33 |
Static Pressure vs Hydrostatic Pressure | MissCFD | CFX | 3 | August 12, 2014 23:29 |
Definition of pressure | Ola Nordblom | FLUENT | 1 | August 16, 2001 15:58 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
