request for surfaceScalarField nHatf error with twoMixingLiquidsMixingFoam
Old   June 15, 2022, 20:46
Default request for surfaceScalarField nHatf error with twoMixingLiquidsMixingFoam
Miriam
myriam656 is on a distinguished road
Hello all,
I am getting the following error with the twoLiquidMixingFoam solver, I am modelling a pipe vertical flow and it has an injection of another liquid in the middle of the pipe. I have no idea where to look for the error... it runs with interfoam but not with this solver. Any suggestions?
--> FOAM FATAL ERROR:
request for surfaceScalarField nHatf from objectRegistry region0 failed
available objects of type surfaceScalarField are
4
rhoPhi
ghf
rhoPhiSum
phi
From function const Type& Foam::objectRegistry::lookupObject(const Foam::word&) const [with Type = const Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>]
in file /home/ubuntu/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 211.
FOAM aborting
#0 Foam::error::printStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const& Foam::objectRegistry::lookupObject<Foam::Geometric Field<double, Foam::fvsPatchField, Foam::surfaceMesh> const>(Foam::word const&) const at ??:?
#3 Foam::interfaceCompressionNew::interpolate(Foam::G eometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at ??:?
#4 Foam::fv::gaussConvectionScheme<double>::flux(Foam ::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at ??:?
#5 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/twoLiquidMixingFoam"
#6 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/twoLiquidMixingFoam"
#7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#8 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/twoLiquidMixingFoam"
Aborted (core dumped)
myriam656 is offline   Reply With Quote
Old   March 6, 2024, 11:06
LeiXu
hhuxulei is on a distinguished road
hello,
Have you solved this problem? I also met it when I want to use the twoLiquidMixingFoam
hhuxulei is offline   Reply With Quote
Old   September 12, 2024, 12:34
RubixxCube is on a distinguished road
I've also encountered this issue while using incompressibleMultiphaseVoF (OF Version 12).
I tested a bit and it seems the issue lies in the divSchemes you choose.
For my div(phi, alpha) I tried "Gauss interfaceCompression vanLeer 1" which
produced the same error.
Using standard vanLeer for my discretization did the trick.
Not sure why interfaceCompression with vanLeer won't work here.
RubixxCube is offline   Reply With Quote
[OpenFOAM] could not open file .vtk in paraview ali_atrian ParaView 8 August 27, 2014 11:31
[OpenFOAM] Saving ParaFoam views and case sail ParaView 9 November 25, 2011 16:46
Problem with paraFoam ata OpenFOAM 14 November 30, 2009 05:23
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
[OpenFOAM] Xwindows crash with paraview save srinath ParaView 1 October 15, 2008 10:37
