Tutorial 2.2 Flow around a cylinder - Not generating results. |
June 13, 2022, 17:53 |
David
Rep Power: 5 |
I'm trying to work through the OpenFOAM tutorials and am frustratingly stuck on the second one. I'm able to mesh and apparently solve without errors, but in ParaView I cannot generate any results (streamlines, p/U fields, etc). Here is what I'm working with: Version: OpenFOAM v. 2112 running on WSL Ubuntu 20.04.4 Tutorial: basic/potentialFoam/cylinder folder is copied to an OpenFOAM directory in my home folder Meshing: After running blockMesh I opened the file in ParaView and confirmed the mesh looks as expected and the walls are correctly named. BCs: See below Solver: See output from the solver below Notes: - I have solved the cavity tutorial and successfully processed p/U fields in ParaView, so I don't believe the issue is translating to the post-processor - I changed the "nNonOrthogonalCorrectors" designation to Zero as per the tutorial's suggestion. I also tried with designation 3 and got same result. - I have checked the fvSolution file and confirmed that potentialFlow is referenced (another question on this forum had this issue) - I did rename the folder "0.orig" to "0" and delete the .orig directory - I tried another attempt by running the "Allrun" file before touching anything in the directory with same results. Does anyone have a suggestion? Is there more information I can provide that would help diagnost this? Thank you kindly BCs: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { down { type symmetryPlane; } right { type zeroGradient; } up { type symmetryPlane; } left { type uniformFixedValue; uniformValue constant (1 0 0); } cylinder { type symmetry; } defaultFaces { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { down { type symmetryPlane; } right { type fixedValue; value uniform 0; } up { type symmetryPlane; } left { type zeroGradient; } cylinder { type symmetry; } defaultFaces { type empty; } } // ************************************************************************* // Code:
user@username-redacted:~/OpenFOAM/cylinder$ potentialFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _80318542-20220301 OPENFOAM=2112 patch=220310 version=2112 Arch : "LSB;label=32;scalar=64" Exec : potentialFoam Date : Jun 13 2022 Time : 15:22:50 Host : username-redacted PID : 794 I/O : uncollated Case : /home/user/OpenFOAM/cylinder nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 potentialFlow: Operating solver in PISO mode Reading velocity field U Constructing pressure field p Constructing velocity potential field Phi No MRF models present Calculating potential flow GAMG: Solving for Phi, Initial residual = 1, Final residual = 0.00645988, No Iterations 5 Continuity error = 0.00169825 Interpolated velocity error = 0.000131161 ExecutionTime = 0.03 s ClockTime = 0 s End |
December 5, 2022, 09:29 |
NickyN
Hi I have faced the same issue. It turned out to be a simple solution: just uncheck "Skip Zero Time" in the properties pane in ParaView.
Looks like potentialFoam is used to create consistent boundary and initial conditions for other solvers. For that reason potentialFoam results are saved to 0/ directory Cheers |
December 5, 2022, 09:32 |
David
Rep Power: 5 |
Thank you! I did end up figuring that out but forgot to update here.
June 2, 2023, 14:27 |
Thank You!
Scott Stevenson
Rep Power: 3 |
I had the same problem. Thanks for helping!
[mesh manipulation] Mirroring flow around cylinder tutorial | Davide95 | OpenFOAM Meshing & Mesh Conversion | 3 | March 31, 2022 08:43 |
Tutorial: flow around a cylinder | TU_Hiwi | OpenFOAM Post-Processing | 12 | May 29, 2020 08:35 |
Problem with grid convergence for turbulent flow around cylinder | aakie | OpenFOAM Running, Solving & CFD | 3 | November 13, 2018 05:39 |
Incorrect Drag and Drag Coefficient for flow over a cylinder | ozzythewise | Main CFD Forum | 8 | June 13, 2012 07:24 |
Incompressible, Unsteady Cylinder Flow | startingcfd | Main CFD Forum | 1 | March 15, 2011 02:12 |
