There is no Temperature change in chtMultiregionFoam |
June 10, 2022, 08:52 |
Rep Power: 4 |
hello, i am beginner of openfoam
i wanted to study the chtMultiregionFoam, so i conducted some example related with chtMultiregionFoam. so i chose the coolingsphere case directory, and then i modified this case folder to practice about this solver as i mentioned above. so, i set two regions, soild and liquid and also i set the heat generation that occured in solid region by using fvoptions. and then i want to see the temperature change or distribution as time goes on, however in any time directory, there is no temperature change, thus, the temperature of system was maintained as initial value that i set in 0 folder.. in other words, the temperature values are not updated in my modified case.. the below picture is "5.0" time directory, from this picture, we can know the temperature in solid region was maintained constant value.. (initial T value is 296K) [IMG]file:///C:/Users/admin/Desktop/%EC%BA%A1%EC%B2%98.JPG[/IMG] i did't know why this problem occured.. can someone tell me some information about this? thank you very much! |
Curved a Mesh - negative initial temperature error in chtMultiRegionFoam | mbranag | OpenFOAM Running, Solving & CFD | 2 | December 9, 2019 17:06 |
Problem with phase change - Relating to TEMPERATURE | Kummi | OpenFOAM Running, Solving & CFD | 0 | August 5, 2019 01:12 |
User Code to change optical properties at certain temperature | RageofaMonkey | STAR-CCM+ | 0 | June 21, 2018 11:46 |
To change temperature in mass flow inlet boundary condition per iteration | ajinkya201991 | FLUENT | 1 | July 11, 2014 11:29 |
Temperature dependent propertys and finalIteration in chtMultiRegionFoam | waiter120 | OpenFOAM | 0 | February 20, 2013 05:22 |
