Stabilizing simpleFoam for Pressure-Driven Flows
Old   June 9, 2022, 19:34
Default Stabilizing simpleFoam for Pressure-Driven Flows
Jared Bland
JEBland is on a distinguished road
I'm attempting to get a square channel toy model working for pressure-driven laminar flow using simpleFoam, and the pressure is quite wild for the first few hundred iterations. The pressure is initialized to (approximately) the average pressure of the inlet & outlet. Is there an efficient way to limit the initial iterations to encourage stability in pressure-driven simulations?
I understand that there might be "shocks" in the flow when setting up pressure based BCs, but I would expect that for an initially still fluid with the interior pressure set to the average pressure of the boundaries, that the peak & min pressures should also be approximately bounded by inlet and outlet pressures - instead the peak min/max values of the pressure at orders of magnitude larger than the final resulting values, even with the relaxation factors set to 0.1 for p and U.
Explicit limitation of p doesn't seem to be respected by simpleFoam, either.
While the pressure-driven BCs are on the list of the -listScalarBCs and -listVectorBCs for potentialFoam, my attempts to initialize with potentialFoam were fruitless. Apparently this isn't new, but to my knowledge, pressure driven flow has not been incorportated into potentialFoam (https://bugs.openfoam.org/view.php?id=1845).
I don't mind that it can take a while to converge in simpleFoam, but it's frustrating that even with the relaxation set to 0.1 that there are still domains moving through and not being smoothed by the solver.
A couple of shallow attempts to bound the solver settings in fvSchemes didn't seem to do much, either.
https://www.openfoam.com/documentati...erical-schemes
https://cfd.direct/openfoam/user-guide/v6-fvSchemes/
Attached are a couple sample images, which represent some of the unstable initial behavior where the inlet has a pressure of 7.3 m^2/S^2 and the outlet has a pressure of 0.52 m^2/s^2. I'm using the totalPressure boundary condition for the pressure and the pressureInletOutlet - from the guide, this combination should have "very good" stability.
p:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  8
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
 dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 3.9 ;
boundaryField
    Leg1InOut // inlet
        type            totalPressure;
        p0              uniform 7.3;
        value           7.3;
    Leg2InOut // outlet
        type            totalPressure;
        p0              uniform 0.52;
        value           0.52;
    walls
        type            fixedFluxPressure;
        value           0;
        gradient        0;
U:
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    Leg1InOut
        type         pressureInletUniformVelocity;
        value        uniform (0 0 0);
    Leg2InOut
        type         pressureInletOutletVelocity;
    walls
        type            noSlip; // zeroGradient;
blockMeshDict:
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
length  1.0;
width   0.1;
height  0.1;
xMin #calc "-0.5 * $length";
xMax #calc " 0.5 * $length";
yMin #calc "-0.5 * $height";
yMax #calc " 0.5 * $height";
zMin #calc "-0.5 * $width";
zMax #calc " 0.5 * $width";
vertices
//                 Leg1
//                 Leg2
    ( $xMin $yMin $zMin) // 0
    ( $xMax $yMin $zMin) // 1
    ( $xMax $yMax $zMin) // 2
    ( $xMin $yMax $zMin) // 3
    ( $xMin $yMin $zMax) // 4
    ( $xMax $yMin $zMax) // 5
    ( $xMax $yMax $zMax) // 6
    ( $xMin $yMax $zMax) // 7
blocks
    hex (0 1 2 3 4 5 6 7) (100 10 10) simpleGrading (1 1 1) // Leg1 - Leg2
edges
boundary
    Leg1InOut
        type patch;
        faces
        (0 4 7 3) // nX
    Leg2InOut
        type patch;
        faces
          (2 6 5 1) // pX
    walls
        type wall;
        faces
          (2 3 6 7) // pY
          (0 1 5 4) // nY bottom
          (1 0 3 2) // nZ
          (4 5 6 7) // pZ
controlDict:
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     simpleFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         10000;
deltaT          1;
writeControl    timeStep;
writeInterval   10;
purgeWrite      0;
writeFormat     binary; // ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
functions
    #includeFunc flowRatePatchpatches
             Leg1InOut
             Leg2InOut
fvSolution:
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
     p
        solver           GAMG;
        tolerance        1e-7;
        relTol           0.01;
        smoother         DICGaussSeidel;
    U
        solver          smoothSolver;
        smoother        GaussSeidel;
        tolerance       1e-05;
        relTol          0;
    "(p|U)Final"
        relTol          0;
SIMPLE
    momentumPredictor no;
    nNonOrthogonalCorrectors 0;
    consistent       no;
    residualControl
        p               1e-4; // 4
        U               1e-5; // 5
relaxationFactors
    fields
        p               0.1;
    equations
         U               0.1;
fvSchemes:
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss upwind;
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
//    default         Gauss linear limited corrected 0.4; // Doesn't do much?
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
Any assistance would be appreciated.
JEBland is offline   Reply With Quote
Old   June 13, 2022, 15:59
Default Relating Mesh size to pressure difference?
Jared Bland
I checked against a sample with pore-based modelling, and the sample had the pressure on the order of 1e-3 (whereas my difference is 1e0 - 1e1). Doing a basic test, I decreased the pressure difference by introducing an order of magnitude so 7.3 becomes 7.3e-3, 3.9 becomes 3.9e-3, and 0.52 becomes 0.52e-3. Then repeated with e-2.. I readily get good convergence for e-3, e-2. But at *e-1, things get substantially slower.
Does the mesh size need to become finer in order to handle the larger pressure differences / faster velocities?
The relaxationFactors are already quite small at 0.05 (reduced from the 0.1 above).
I'm tinkering with just mapping the internal fields a la this thread:
MapFields only on internal fields
Initial test seems to work, but will see if I'm able to "turn on" the pressure bit by bit.
Edit: Looks like it needs a finer mesh, too. Will play with refining the mesh as well as mapping the previous fields in order to get more stability.
laminar, pressure boundary, simplefoam
lid driven turbulent flows student Main CFD Forum 0 July 20, 2007 13:43
Pressure correction in Buoyancy driven flows Aditya Main CFD Forum 0 March 8, 2007 07:36
Buoyancy Driven Flows Aditya Main CFD Forum 0 May 26, 2006 03:07
Buoyancy driven flows A. Guardo FLUENT 9 March 25, 2004 10:12
buoyancy driven flows anevin Main CFD Forum 2 January 1, 1999 00:56
