June 9, 2022, 05:03 |
interIsoFoam extremely slow
Lilly
Rep Power: 12 |
Dear Foamers,
I want to simulate a fixed ship (JBC) with free surface, and wanted to try interIsoFoam (v2006). Before, I did some simulations using interFoam, now I did not change anything except the solver. The mesh was made with Pointwise and consists mainly of triangles/ tets. It has 8.5 million cells, which I distribute over 160 cores (on a cluster), with a y+ = 40...80. The checkMesh utility did not give any warnings. Now when I start the simulation, I do not get any errors/ warnings, also the results look reasonable, and only few iterations are done for pressure etc. However, each iteration takes ages...it needs around 30s for each. With my timestep being 0.0002s and a simulation time of 35s, this is not acceptable, especially as interIsoFoam is said to be faster than interFoam. Did I miss something regarding the application area of interIsoFoam? Do you have any idea what might be the reason? Attached you will find the boundary conditions (which worked fine with interFoam) and the system files. Thanks in advance! |
free surface, interfoam, interisofoam, ship flow |
Case running extremely slow on cluster in parallel mode | Venky_94 | OpenFOAM Running, Solving & CFD | 3 | August 28, 2024 20:10 |
Extremely slow Lagrangian Particle Tracking | robertac93 | STAR-CCM+ | 3 | April 17, 2020 00:25 |
[ANSYS Meshing] export to CGNS extremely slow | Renold | ANSYS Meshing & Geometry | 1 | April 24, 2019 19:54 |
[ANSYS Meshing] meshing extremely slow | dynamic | ANSYS Meshing & Geometry | 3 | February 15, 2017 06:11 |
Extremely slow simulation with interDyMFoam | jrrygg | OpenFOAM Running, Solving & CFD | 9 | April 23, 2013 11:14 |
