Need processor boundary condition guide
Old   June 9, 2022, 03:16
Default Need processor boundary condition guide
ff
fxzf is on a distinguished road
Hello Foamers,
I need to understand more how OpenFOAM parallel boundary processor works, especially, how the processor boundary help to assemble the matrix, how does the processor boundary contribute the off-diag of neighbour cell?
Thanks very much.
fxzf is offline   Reply With Quote
Old   June 13, 2022, 02:12
ff
Originally Posted by fxzf View Post
Hello Foamers,
Thanks very much.
Can anyone help? I would like to know how the zero-halo layer works?
Thanks a lot.
Old   June 13, 2022, 13:43
Domenico Lahaye
dlahaye is on a distinguished road
Could you please elaborate your query and explain in more details what you are looking for?
Is your query related to the discretization process (finite volume counterpart of divergence or gradient)?
Or is your query related related to the linear system solve process?
Assume that processor i is connected to various processor j. Then information on how processor i is connected to processor j in stored on processor i in the zero-halo layer for processor j.
The exact nature on what information is stored and how this information is use requires further discussion.
Does this help?
EDIT: a nice illustration of zero-halo layers is given in post number 7 of the thread lduMesh, lduAddressing and thisDb()
dlahaye is offline   Reply With Quote
Old   June 16, 2022, 02:41
ff
Does this help?
Hi dlahaye,
Thanks very much for your reply.
So what I am looking for is a bit both side, the discretization process and the linear system solve process.
We can use the following site as example:
https://openfoamwiki.net/index.php/O...es_in_OpenFOAM
So we can focus this simple 3x3 grid with 9 cells for simple laplacian equation.
It is very straight forward, in single processor mode, we can build up this 9x9 matrix.
Let's focus on cell index 5 since it has no boundary patch linked, the neighbour cells of cell 5 are 2,4,6,8.
Therefore, on matrix, there is coefficient on matrix index are diagonal (4,4), and off-diagonal (4,1), (4,3), (4,5) (4,7).
Now, if we split the mesh at cell 1,6,7. The faces between cell (1,2), (6,5), (7,8) will be converted into processor type boundary patch.
Let's say cells 1,6,7 on processor rank 0, cells 2,3,5,4,8,9 on processor rank 1.
Then, on processor 0, we will build up matrix 3x3 locally, and on processor 1, we will build up a matrix 6x6 locally.
Traditionally, we need to contrust dummy layer on processor 0 and processor 1.
So in traditional way, processor 0, will receive the information of cell 2, 5, 8 from processor 1, and build up matrix 6x6 locally. And processor 1 will receive the cell 1,6,7 information, and build up 9x9 matrix locally.
But in openFoam, I don't see boundary processor transferentire neighbour cell information, and it only implement as local patch boundary condition with face information transferred.
So I am a bit confused how OpenFOAM build up the parallel matrix.
Old   June 16, 2022, 03:12
ff
So let's trace the OpenFOAM code,
1. in gaussLaplacianScheme,
we have
if pvf.coupled
   fvm.internalCoeffs()[patchi] =
                pGamma*pvf.gradientInternalCoeffs(pDeltaCoeffs);
            fvm.boundaryCoeffs()[patchi] =
               -pGamma*pvf.gradientBoundaryCoeffs(pDeltaCoeffs);
where pDeltaCoeffs is the distance between owner cell center to processor patch face centre. pGamma is surface area mag * gamma(like thermal conductivity). (corrected me if I am wrong)
2. Then processor coupled patch, processorFvPatchField->coupledFvPatchField-> gradientInternalCoeffs will be called.
Foam::coupledFvPatchField<Type>::gradientInternalCoeffs
    const scalarField& deltaCoeffs
) const
    return -Type(pTraits<Type>::one)*deltaCoeffs;
Foam::coupledFvPatchField<Type>::gradientBoundaryCoeffs
) const
    return -this->gradientInternalCoeffs(deltaCoeffs);
This one is only -1/distance(cellcentre to face) * gamma*SurfaceArea added into fvm.internalCoeffs().
3. in fvMatrixSolve
Foam::SolverPerformance<Type> Foam::fvMatrix<Type>::solveSegregated
it runs addBoundarySource, which
void Foam::fvMatrix<Type>::addBoundarySource
    Field<Type>& source,
    const bool couples
) const
    forAll(psi_.boundaryField(), patchi)
        const fvPatchField<Type>& ptf = psi_.boundaryField()[patchi];
        const Field<Type>& pbc = boundaryCoeffs_[patchi];
        if (!ptf.coupled())
            addToInternalField(lduAddr().patchAddr(patchi), pbc, source);
        else if (couples)
            const tmp<Field<Type>> tpnf = ptf.patchNeighbourField();
            const Field<Type>& pnf = tpnf();
            const labelUList& addr = lduAddr().patchAddr(patchi);
            forAll(addr, facei)
                source[addr[facei]] += cmptMultiply(pbc[facei], pnf[facei]);
So here, I don't really understand why it need to multiply owner and neighbour cells boundaryCoeffs?
4. the it runs
           updateMatrixInterfaces
                true,
                bouCoeffsCmpt,
                interfaces,
                psiCmpt_ss(),
                sourceCmpt_ss.ref(),
                cmpt,
                startRequest
which is in
lduMatrixUpdateMatrixInterfaces.C
void Foam::lduMatrix::updateMatrixInterfaces
interfaces[interfacei].updateInterfaceMatrix
                                result,
                                add,
                                psiif,
                                coupleCoeffs[interfacei],
                                cmpt,
                                Pstream::defaultCommsType
5. Above will call in processorFvPatchField->updateInterfaceMatrix
void Foam::processorFvPatchField<Type>::updateInterfaceMatrix
    Field<Type>& result,
    const bool add,
    const Field<Type>&,
    const scalarField& coeffs,
    const Pstream::commsTypes commsType
) const
transformCoupleField(receiveBuf_);
// Multiply the field by coefficients and add into the result
this->addToInternalField(result, !add, coeffs, receiveBuf_);
Not really sure what this receiveBuf_ is?
6. this will call the LduInterfaceField
template<class Type>
void Foam::lduInterfaceField::addToInternalField
    const bool add,
    const Field<Type>& vals
) const
    const labelUList& faceCells = this->interface().faceCells();
    if (add)
        forAll(faceCells, elemI)
            result[faceCells[elemI]] += coeffs[elemI]*vals[elemI];
    else
            result[faceCells[elemI]] -= coeffs[elemI]*vals[elemI];
Follow the entire process, so it seems it first multiply the boundary coefficients (which is -1*gradientInternalCoeff) if owner and neighbour side of processor boundary. Then, it deduced this -= coeffs[elemI]*receiveBuf_[elemI].
So the processor boundary is only contribute the matrix system's diagonal and right side source term.
This is mainly a bit confused me, how openfoam only build up the parallel matrix at processor boundary with only affect diagonal and source term of matrix to get the same solution of single matrix.
Old   June 16, 2022, 07:06
Domenico Lahaye
Thank you for further elaborating. I much like your ideas.
I suggest to separate between discretization and linear system solve.
The discretization is well discribed is the book by Moukalled and Darwish (at least for the sequential case). I am not able to answer your queries on discretization on short term.
The linear solve is done by a preconditioned Krylov subspace method implemented in parallel. One can thus analyse how the required vector and matrix-vector operations are implemented in OpenFoam. A start of this analysis is given in https://www.linkedin.com/pulse/openf...menico-lahaye/
I imagine that you are overlooking ingredients when stating that "only diagonal elements" are modified/used.
I much like your suggestion of looking into a small example. One could draw a scheme of the matrix decomposition (including the interfaces), further examine the code and use a parallel debugger to verify the perceived understanding.
Does this make sense?
Nasa Rotor 37 Stuck at Choked Condition okumush OpenFOAM Running, Solving & CFD 2 July 31, 2021 06:30
The difference of cyclic boundry condition and mapped boundary condition caitao OpenFOAM Running, Solving & CFD 1 December 4, 2019 08:29
Accessing multiple boundary patches from a custom boundary condition file ripudaman OpenFOAM Programming & Development 0 October 22, 2014 19:34
what "If" condition means in rebound brbbhatti OpenFOAM Programming & Development 0 August 12, 2014 10:18
Internal flow operating condition? kookguy FLUENT 2 June 26, 2014 01:15
