Using steady state simulation as initial condition in another solver |
June 3, 2022, 20:49 |
Rep Power: 4 |
Hi OpenFoam community,
I just started using the software and have a newbish question. I have done a simulation with simpleFoam to get a steady state condition. Now I want to use this steadystate condition (velocity and pressure) in another simulation as the initial condition. The mesh is exactly the same. Can I just copy the results from the latest time step into the 0/ directory and erase the location and arch from the header in FoamFile? Is copy/paste enough? Is there a utility to do this? What is the procedure? |
June 6, 2022, 04:37 |
#3 | |
Rep Power: 4 |
What if the second solver is transient? To your knowledge is there a problem with copying the files into the zero folder to use as initial condition? Best regards, |
Suppress twoPhaseEulerFoam energy | AlmostSurelyRob | OpenFOAM Running, Solving & CFD | 33 | September 25, 2018 18:45 |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 13:30 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 03:20 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
