questions on movingCylinderInChannellco in Foam-Extend 4.1
Old   May 31, 2022, 10:35
Default questions on movingCylinderInChannellco in Foam-Extend 4.1
cyh
cyhpku is on a distinguished road
hi everyone. I'm new to fe41 and currently studying ibm in it.I already read Hrvoje Jasak's ppt but still confused at the tutorial case of movingCylinderInChannellco.
1.Jasak's ppt said "copy immersed boundary mesh (ibCylinder,{ftr,stl}) into constant/triSurface folder". I am confused at the ibCylinder.ftr . It read as follows:
1
cylinder
patch
96
(0.176776 -0.176776 -0.05)
(0.176776 -0.176776 0.05)
(-0.095671 -0.23097 -0.05)
96
((0 64 65) 0)
((65 1 0) 0)
((7 6 79) 0)
it seems that the first part is the list of coordinate of the vertex which is numbered from 0~95,the second part is a list of triangle faces defined by three vetexs, but what does the following 0 mean? for example, I know (0 64 65) is a triangle surface ,but what does the other 0 mean in((0 64 65) 0)?
2.If the lagrange vertexes are defined that way,how can I set up an ib structure that can defrom? For example,let half of the vertex of the cylinder move with prescribed velocity and let the other half move passively. Other ibm software like ibamr or ib2d gives structer like spring,beam...etc, how ib in fe41 work to deal with fsi ,or ib structers' passive deformation?
cyhpku is offline   Reply With Quote
foam-extend 4.1, immersed boundary method.
[foam-extend.org] Installing Foam Extend 4.0 on Linux Mint andysuth OpenFOAM Installation 1 May 11, 2019 09:37
[mesh manipulation] refineMesh Error mohsen.boojari OpenFOAM Meshing & Mesh Conversion 3 March 1, 2018 23:07
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
