Mass conservation in engineFoam with cyclic boundary conditions |
May 30, 2022, 20:00 |
Marco A. Turcios
Rep Power: 28 |
I am having issues updating a solver from OpenFOAM 2.3.1 to 9. It is based on sprayEngineFoam/engineFoam, but it seems that cyclic boundary conditions with the layered mesh are no longer working in OpenFOAM 9.
I've submitted a bug report, but am wondering if anyone has run into the same issue here: https://bugs.openfoam.org/view.php?id=3845 You can download the test case and run engineFoam and see how there is a significant loss of mass. This does not occur in OpenFoam 2.3.1 under sprayEngineFoam, nor does it occur in OpenFOAM 9 when the boundaries are all closed or a cyclic mesh that doesn't move. I am currently testing to see if it OpenFOAM 7 or 8 work, as it seems the way cyclic transforms work changes in OF8. Any help would be greatly appreciated |
cyclic boundary violates mass conservation | Maik | OpenFOAM Running, Solving & CFD | 13 | August 23, 2016 10:25 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 09:16 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
