Convergence Problems in rhoSimpleFoam with Complex Mesh
Old   May 29, 2022, 13:30
Question Convergence Problems in rhoSimpleFoam with Complex Mesh
Anuar Giménez
anuargimenez is on a distinguished road
Hi all,
I am trying to simulate a polymer flow through a single screw extruder, such as the one shown below:
I modified some libraries to correctly introduce the non-Newtonian fluid behavior and ran some simulations with simple geometries to check that everything worked fine. They converge very well and have physical meaning.
Then, I changed to a more complex geometry, as the one shown in the attachment. It is a static single screw extruder, i am not considering the rotation of the screw.
The problem is that I cannot achieve convergence. The enthalpy is going well, however the velocities and pressure remain constant between e-3 and e-4. An image of residuals is attached.
It is a stationary simulation, using rhoSimpleFoam.
My initial conditions are:
|  \\    /   O peration     | Version:  v2112                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 1e5;
boundaryField
    wall1
        type            fixedFluxPressure;
        value           uniform 0;
    wall2
        value           uniform 0;
    screw
        value           uniform 0;
    outlet
        type            fixedValue;
        value           uniform 1e5;
    inlet
        type            zeroGradient;
FoamFile
    version     2.0;
    format      ascii;
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 405.65; //initial condition
boundaryField
    wall1
	type            	convectiveRadiativeHeatFlux;
	mode            	convectiveRadiative;
	Ta              	constant 513.15;
	h               	uniform 215;			//Heat transfer coefficient    [W/(m²*K)]
	emissivityNozzle	0.95;				//Emissivity nozzle (or brass) [-]
	emissivityFilament	0.95;				//Emissivity filament [-]
	dNozzle		4.0;				//inner diameter nozzle [mm}
	dFilament		1.75;				//filament diameter [mm]
        kappaMethod     	fluidThermo;
        value           	$internalField;		//initial Temperature value
    wall2
        type            fixedValue;
        value           uniform 513.15; // solo calor en la zona 2
    screw
        type            zeroGradient;
    outlet
        type            zeroGradient;
    inlet
        type            fixedValue;
        value           uniform 298.15; // temperature ambient 25ºC
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    wall1
        type            slip;
    wall2
        type            noSlip;
    screw
        type            slip;
    outlet
        type            zeroGradient;
    inlet
        type            flowRateInletVelocity;
        massFlowRate    constant 1e-05; // kg/s
        rho             rho;
        rhoInlet        1000;    // Guess for rho
controlDict:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      controlDict;
application     polymSimpleFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         0.003;
deltaT          0.00000005; //Time step should be chosen so small that a Courant number is less than 1
writeControl    timeStep;
writeInterval   600; //Number of output folders or steps in ParaView (deltaT*writeInterval = step width of the folders)
purgeWrite      0;
writeFormat     binary;
writePrecision  10;
writeCompression off;
timeFormat      general;
timePrecision   6;
graphFormat     raw;
runTimeModifiable true;
//_______below additional outputs and options
functions //https://www.openfoam.com/documentation/guides/latest/doc/guide-function-objects.html
	// Writes the residuals for each iteration step to a file in the postProcessing folder, graphing while solving via the "AllMonitor" script
	residual1
		type		residuals;
		libs		("libutilityFunctionObjects.so");
		writeInterval   1;
		fields (p U h);
	// The fieldMinMax function object computes the values and locations of field minima and maxima. These are good indicators of calculation performance, e.g. to confirm that predicted results are within expected bounds, or how well a case is converging.
	minMax
		type            volFieldValue;
		libs            ("libfieldFunctionObjects.so");
		fields          (U p);
		executeControl  writeTime;
		writeControl    writeTime;
		writeFields	false;
		log		false;
		regionType	all;
		operation	max;
	writeThermophysicalProperties
		type		writeObjects;
		objects	(thermo:alpha thermo:mu);
		//executeControl	timeStep;
		//writeInterval	60;
fvSchemes:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default             steadyState;
gradSchemes
    default         Gauss linear upwind;
    limited         cellLimited Gauss linear 0.1;
    grad(U)         $limited;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss linearUpwind grad(U);
    energy          bounded Gauss linearUpwind limited;
    div(phi,e)      bounded Gauss linearUpwind limited;
    div(phi,Ekp)    bounded Gauss linearUpwind limited;
    div(phi,h)      bounded Gauss linearUpwind limited;
    div(phi,K)      bounded Gauss linearUpwind limited;
    div(((rho*nuEff)*dev2(T(grad(U)))))    Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fvSolution:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    p
        solver          	GAMG;
        preconditioner  	GAMG;
        tolerance       	1e-07;
        relTol          	0.1;
	smoother		DICGaussSeidel;
	cacheAgglomeration	true;
	nCellsInCoarsestLevel	145;
	agglomerator		faceAreaPair;
	mergeLevels		1;
	directSolveCoarsest	false;
    U
        solver         smoothSolver;
	smoother	GaussSeidel;
        nSweeps		1;
        tolerance       1e-08;
        relTol          0.01;
    "(e|h)"
        nSweeps		2;
        tolerance       1e-09;
        relTol          0.01;
SIMPLE
    nNonOrthogonalCorrectors 2;
    pMinFactor      0.99;
    pMaxFactor      200;
    transonic       no;
    consistent      yes;
    rhoMax          rhoMax [ 1 -3 0 0 0 0 0 ] 1.2;
    rhoMin          rhoMin [ 1 -3 0 0 0 0 0 ] 0.9;
    residualControl
        p               1e-6;
        U               1e-5;
        h		 1e-7;
relaxationFactors
    U               0.6;
    p               0.5;
    rho             0.01;
    h               0.5;
I already try to refine the mesh, but the residuals remain almost the same.
It would be a great help if you could give me some advice to improve convergence.
Thanks,
Anuar
anuargimenez is offline   Reply With Quote
Old   May 30, 2022, 07:05
Lukas
Pappelau is on a distinguished road
Hello Anuar,
from shortly locking on your case :
Your control dict "looks" like a transient simualtion but u defined steadystate in fvSchemes....
this is pure optics
From your resiudal plot your case is converging very well.. they not need to be very low for good convergence. More important are your physical parameters like temperature distribution and flowfield speed. Never only watch residuals they just show you the direction if something is odd.
But...
IF you use consistent setting with simple (SIMPLEC) your under relaxation should be near 1 for pressure and rho and 0.95 for other convectives (https://www.openfoam.com/documentati...orithm-control) Chapter 6.3.2
Pappelau is offline   Reply With Quote
Old   May 30, 2022, 17:21
Smile
Anuar Giménez
Originally Posted by Pappelau View Post
Hello Anuar,
this is pure optics
But...
Hi Pappelau,
thank you so much for your quick response.
I read somewhere on the internet, that to improve convergence it is convenient to decrease the number of Courant, so I set a very small timestep. However, as you say, since it is a stationary simulation, without time derivative, it is useless. I have corrected this by setting dt = 1.
I have no experience with the SIMPLEC algorithm, your answer was very helpful. I have changed the under relaxation coefficients to:
relaxationFactors
    U               0.9;
    p               1;
    rho             1;
    h               0.9;
After these changes, here is the residuals plot:
It behaves a little unstable at the beginning and then converges with a little high residual. I have to mention that small changes in the relaxationFactors values highly affect the residuals plot. I don't know if I could consider this a good convergence. Maybe a change in fvSchemes would help to improve this.
Regarding the physical meaning of the simulation with these parameters, the temperature seems ok. However, the velocity (and therefore pressure) do not make me feel confident (which does not mean that they are wrong).
The boundary condition for inlet velocity is as follows:
    inlet
        massFlowRate        3e-05;// kg/s
        extrapolateProfile  yes;
        rho                 rho;
        rhoInlet            1040;
        value               uniform (0 0 0);
And the posprocessing is shown below:
Temperature:
Pressure:
Velocity:
I would greatly appreciate your opinion.
Thanks,
Anuar
Old   June 1, 2022, 02:57
Lukas
Good Morning,
from my Point of View the resiudals are just fine, they show a nice convergence .
the Pictures for Temperature seems very plausible also for velocity. The pressure goes high due to expansion(heating)(of your polymer), I assume ? (Never worked with that specific solver nor the underlying physics)
As you mentioned your fvSchemes u can always take a look at:
https://cfd.direct/openfoam/user-guide/v9-fvschemes/
Here u find good information on "practical" values
convergence, openfoam, residuals, rhosimplefoam, simplefoam
Convergence problems unsteady conjugate heat flow problem when refining mesh Sven_netherlands COMSOL 0 December 2, 2020 05:32
[blockMesh] mesh causing problems with convergence Tetragramm OpenFOAM Meshing & Mesh Conversion 0 September 22, 2012 17:00
increasing mesh quality is leading to poor convergence tippo CFX 2 May 5, 2009 11:55
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
