The use of mappedWall boundaries for chtMultiRegionFoam |
May 26, 2022, 13:04 |
Rep Power: 4 |
Hello to all,
I am performing a chtMultiRegionFoam simulation where the fluid domain is inside the solid domain. After generating the mesh I assigned the inlet and outlet with topoSet Maintain patchs in interior mesh for SHM in multiRegion My inlet, outlet and walls are of type mappedWall. This will be used to couple the temperature between the fluid and solid domain through the boundary compressible::turbulentTemperatureCoupledBaffleMix ed or equivalent. My question is.. Will this type of boundary have any influence on the fluid flow variables that are not being coupled [p, U, etc.] ? Will they work as standard "patch" type? Best regards |
Periodic Interface: Symmetry Boundaries are not matching | mazhar16823 | Main CFD Forum | 2 | August 29, 2020 18:30 |
2D Rotating Detonation Engine Periodic Boundaries | whitet86 | FLUENT | 2 | June 25, 2015 12:04 |
Setting Flow/Pressure Boundaries in Floworks | Eran | FloEFD, FloWorks & FloTHERM | 3 | August 11, 2009 05:23 |
periodic boundaries - flow through a net | PK | FLUENT | 0 | July 12, 2007 12:58 |
Periodic Boundaries in GAMBIT!! | swetha | FLUENT | 1 | November 26, 2006 23:02 |
