Wrong result with 6DOF? Pitch up moment but decreasing acceleration
Old   May 20, 2022, 03:28
Default Wrong result with 6DOF? Pitch up moment but decreasing acceleration
TWB
quarkz is on a distinguished road
I'm trying to simulate 2 cases:
1. an aircraft with 1dof in pitch.
2. an aircraft with 2dof in pitch and vertical translation.
In case 1, the aircraft pitches up and remains constant after a while. Pitch moment is approximately zero.
In case 2, aircraft pitches up and then down. Similarly, the angular velocity (vel)changes from positive to negative, which explains the aircraft pitching up and then down.
Pitch moment increases from zero to a maximum before decreasing again. However, it is always positive. But how is it possible that the aircraft pitches down after a while. As moment is positive, the angular acceleration (acc) will always be positive since:
Moment = I*acc
If acc is always positive, how can the vel change from positive to negative?
Is there anyone who knows the reason?
Thanks.
quarkz is offline   Reply With Quote
Old   July 21, 2022, 05:25
TWB
I managed to solve the problem. It is due to the reference frame of the moment calculation. It is explained here:
Confusion abt cm & CofR position in 6dof and non-6dof scenarios
udf error srihari FLUENT 1 October 31, 2016 15:18
Warning: Dynamic zone with wrong CG using 6DOF Manoj Kumar FLUENT 1 August 11, 2012 05:03
UDF extern variable - mean time moment coefficient enry Fluent UDF and Scheme Programming 0 November 14, 2009 07:51
Wrong result with bilinear interpolation zonexo Main CFD Forum 1 June 12, 2007 16:55
laminar pipe flow? Fluent gives wrong result SAM FLUENT 2 November 5, 2004 02:39
