How to get convergence with simpleFoam?
Old   May 18, 2022, 04:48
Smile How to get convergence with simpleFoam?
Denny Mathew Alex
dennymathewalex is on a distinguished road
Hello Everyone 😊,
I am Denny and I am new to OpenFoam. I am learning OpenFoam by simulating a flow inside a rectangular chamber with simpleFoam solver. The boundaries are shown in the figures (inlet-Green, outlet-Red, wall-Blue). The geometry was created using Salome and mesh was generated using snappyHexMesh (only castellated Mesh part is True). Using the checkMesh, the quality of the mesh is OK. I ran the simulation to 2000 and 6000 time steps with delta t of 1 but could not achieve convergence. I have attached the velocity plot for time steps 1802 and 1902.
I have pasted the boundary condition U and p, controlDict, fvSchemes, fvSolution below.
What are the steps to be taken to get a good convergence in this case?
Thank you for your help 😊.
-------------------- U --------------------------------
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (1 0 0);
outlet
type zeroGradient;
value uniform (0 0 0);
wall
type noSlip;
---------------- p ----------------------------
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
wall
type zeroGradient;
--------------------- controlDict ------------------------
application simpleFoam;
startFrom startTime;
startTime 1;
stopAt endTime;
endTime 6000;
deltaT 1;
writeControl timeStep;
writeInterval 100;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
--------------- fvSchemes ---------------------
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) bounded Gauss upwind;
div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
------------------- fvSolution ---------------------
solvers
p
solver GAMG;
tolerance 1e-06;
relTol 0.1;
smoother GaussSeidel;
U
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-05;
relTol 0.1;
SIMPLE
nNonOrthogonalCorrectors 0;
nCorrectors 3;
consistent yes;
residualControl
p 1e-2;
U 1e-3;
relaxationFactors
fields
p 1;
equations
U 0.9; // 0.9 is more stable but 0.95 more convergent
dennymathewalex is offline   Reply With Quote
simpleFoam : how to optimize timestep and assess convergence ? Talder OpenFOAM Running, Solving & CFD 2 February 15, 2019 08:48
Simplefoam Convergence Problem after Scaling by 0.001 CFDy OpenFOAM Running, Solving & CFD 4 July 23, 2018 04:27
SimpleFoam: Residual convergence problem miha23 OpenFOAM Running, Solving & CFD 0 April 24, 2018 19:50
Mesh Convergence Study - simpleFoam: Confusing Results Karpfen OpenFOAM 0 February 5, 2018 08:34
no convergence with simplefoam hei@ge OpenFOAM 14 May 22, 2012 09:34
