Unit of Parameters in rhoCentralFoam
Old   May 13, 2022, 17:05
Question Unit of Parameters in rhoCentralFoam
Fuad Hasibul Hasan
fuad is on a distinguished road
I am trying to modify the $FOAM_TUTORIAL/compressible/rhoCentralFoam/forwardStep of OF-2106. Then I only changed the values of velocity, pressure, temperature, and thermophysical properties to S.I. units. While this tutorial uses normalized gas. Changed the velocity, temperature, pressure from unity to 930 m/s, 873 K and 1.35e7 Pa respectively. The constant/thermoPhysicalProperties file looks like this.
|  \\    /   O peration     | Version:  v2106                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      thermophysicalProperties;
thermoType
    type            hePsiThermo;
    mixture         pureMixture;
    transport       polynomial;
    thermo          hPolynomial;
    equationOfState PengRobinsonGas;
    specie          specie;
    energy          sensibleEnthalpy;
// Note: these are the properties for a "normalised" inviscid gas
//       for which the speed of sound is 1 m/s at a temperature of 1K
//       and gamma = 7/5
mixture
    specie
        molWeight       18;
    thermodynamics
       CpCoeffs<8>     ( 3.91269e4 -1.17335e2 1.2620e-1 4.556e-5 0 0 0 0 ); //
       Hf		3.59431e06;
       Sf		6735.18;
    transport
       muCoeffs<8>     ( 1000 -0.05 0.003 0 0 0 0 0 ); //
       kappaCoeffs<8>  ( -1.3719e-5 7.136029e-8 -2.4915e-11 5.6244e-15 0 0 0 0 ); //
    equationOfState
        Tc        647.27; // critical temp (K)
        Vc        0.056; // critical volume (m^3/kmol)
        Pc        22.12e6; //critical pressure (Pa)
        omega     0.343; // acentric factor (-)
This causes either the simulation to diverge or to maximum number of iteration error.
Is this problem related to unit of the parameters? I've checked other tutorials for rhoCentralFoam and they use S.I. unit. I am not sure what causes this issue. I tried a lot of solutions provided in this forum but none of them worked.
Here is a log file attached for convenience.
fuad is offline   Reply With Quote
Old   December 14, 2023, 19:27
Leckie is on a distinguished road
What I can say about this, based on the OpenFoam documentation, is that rhoCentralFoam is already working with Mach Number reference; therefore the initial velocity parameter "3" is referring to Mach Number 3.
In this case, if you're using 980, it is not 980m/s but Mach Number 980.
Leckie is offline   Reply With Quote
normalised parameter, normalization, rhocentrafoam, s.i. unit
Unit of Parameters in rhoCentralFoam fuad OpenFOAM Running, Solving & CFD 0 May 13, 2022 17:00
Solver parameters to solve convergence issue WilliamH SU2 5 February 5, 2021 07:19
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 06:52
Grid I Unit Normal and Grid J Unit Normal pawansut Tecplot 4 July 31, 2017 19:14
how to caculate the mass of impacting particles per unit area and per unit time? xyq916 CFX 0 October 8, 2015 09:55
