engineTime in OF-9 not writing out timesteps for specific configurations |
May 9, 2022, 17:43 |
Marco A. Turcios
Rep Power: 28 |
Hello all,
I'm updating some old solvers up to OpenFoam-9, and an running into an issue with writing out timestep directories. If I use writeControl of timeSteps, cpuTime, clockTime, everything works as expected. However, I want to write at a specific crank angle, so in the past I've used adjustableRunTime and set the adjustTimeStep to yes and this has worked out fine. When running engineFoam/XiEngineFoam in OpenFOAM-9, this no longer outputs any timestep. I suspect this has to do with conversion from simulation time to crank angle. Has anyone else experienced this? The tutorial kivaTest with XiFoam uses runTime and a non adjustable time step. |
May 9, 2022, 18:50 |
Marco A. Turcios
Rep Power: 28 |
After some digging, I see that there was a fix pushed 5 months ago (I am using the downloadable source pack). The beginTime_ hadn't been set properly.
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 03:36 |
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? | EternalSeekerX | SU2 | 3 | October 9, 2020 19:28 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
[snappyHexMesh] crash sHM | H25E | OpenFOAM Meshing & Mesh Conversion | 11 | November 10, 2014 12:27 |
