Flashing test case openFOAM
Old   May 6, 2022, 10:02
Default Flashing test case openFOAM
Vittorio Cossu
vitco is on a distinguished road
Hi everyone! I am new to cfd-online, but I've always read CFD stuff and you are great!
Does anybody know how to simulate a virtual wall on openfoam? I would like to simulate a burst disk, which after the rupture connects two environment at different pressure.
I used codeStream to simulate different initial condition for the internal flow. My idea was that with those initial condition, the start of the transient simulates the rupture of the disk, is it appropriate?
I run the simulation with cavitatingFoam since as first attempt I was trying to use an HEM model to simulate the flashing, the results shows that the pressure increase only in the region where the system was initialized at lower pressure whilst remaing constant at high pressure where the region was iniitialized at high pressure.
Can anybody help? I've already post this question in the pre-processing forum but I did not receive any answer.
Thank you.
Best regards,
Vittorio
vitco is offline   Reply With Quote
burst disk, cavitatingfoam, flashing flow
Some problems in naca 0012 V&V case of NASA TMR and DPW using OpenFOAM chengdi OpenFOAM Running, Solving & CFD 7 October 5, 2019 14:20
Large test case for running OpenFoam in parallel fhy OpenFOAM Running, Solving & CFD 23 April 6, 2019 10:55
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 04:18
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
