KOmegaSSTLM divergance Problem
Old   May 5, 2022, 13:40
Default KOmegaSSTLM divergance Problem
Abdelrahman Kamaleldin
akamal1099 is on a distinguished road
Hello my friends,
I am experiencing some issues with KOmegaSSTLM using simpleFoam.
I am trying to simulate flow over an airfoil with slotted flap.
I used the boundary conditions which is found in the T3A tutorial for KOmegaSSTLM but the solution diverges.
I tried some troubleshooting and I will write down below summary of it:
1- Everything is fine when there is no layers around the airfoil and flap.
2- When I added layers the solution starts diverging for unknown reason.
3- Same thing happens with KOmegaSST
My layer was made to target y+ of 1 and my mesh is fine per meshCheck.
I am suspecting and error with boundary conditions due to me using wallfunctions for nut, omega and k.
Thanks my friends
Following is the omega file as an example.
I edited it to be zeroGradient because I have y+ equal to 1 and I don't need wallfunctions but still don't work. (Same for k and nut)
also my mesh is attached
|  \\    /   O peration     | Version:  v2012                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      omega;
dimensions      [0 0 -1 0 0 0 0];
internalField   uniform 1.7520318313820673;
boundaryField
    inlet
        type            fixedValue;
        value           $internalField;
    outlet
        type            zeroGradient;
	airfoilZeroDegSurf
        type            zeroGradient;
	flapFiftyDegSurf
        type            zeroGradient;
    upperEmpty
        type            empty;
	lowerEmpty
        type            empty;
	front
        type            symmetry;
	back
        type            symmetry;
akamal1099 is offline   Reply With Quote
Old   May 6, 2022, 16:32
Default ?
Guys any idea?
Old   March 13, 2023, 15:36
Farzad Faraji
farzadmech is on a distinguished road
Hello
did you know how to solve it? my simulation is also diverges.
Thanks,
Farzad
Originally Posted by akamal1099 View Post
Guys any idea?
farzadmech is offline   Reply With Quote
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
BuoyantBoussinesqSimpleFoam_Facing problem Mondal131211 OpenFOAM Running, Solving & CFD 1 April 10, 2019 20:41
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
