May 2, 2022, 20:58 |
Best simulation for turbulent pipe flow
BH
Rep Power: 5 |
I'd like a simulation to match the Moody chart data published here:
https://authors.library.caltech.edu/...MCKEjfm04a.pdf Direct Numerical Simulation with a full 3D-meshed long pipe should work, but will take too long to run. Instead, what is the best way to model turbulence in a 2D representation? Pipe flow really only has 1D of freedom, so this seems easy at first, but I'm not very familiar with turbulence models... By the way, I'm thinking to avoid the common k-epsilon model of turbulence because it requires "wall functions" with a minimum y+ (also, I prefer the log-law "wall functions" to be an output of the simulation instead of being an input). Instead, I need the simulation method to work in the limit of an infinitely-fine mesh. Is there a way to run k-epsilon on this case without "wall functions"? In case that leads to k-omega, is k-omega good for my goal? If I am misunderstanding the k-epsilon model, please correct me, thanks! |
k-epsilon k-omega, turbulance |
[ANSYS Meshing] YPlus for simple pipe flow simulation in CFX | Rischa | ANSYS Meshing & Geometry | 0 | September 7, 2020 10:06 |
Simulation of flow behaviour in complex pipe systems | maybee | OpenFOAM Running, Solving & CFD | 2 | July 16, 2018 12:58 |
Y pipe flow simulation | iv1985 | CFX | 2 | June 24, 2014 02:35 |
Blockage in pipe ( using solidwork flow simulation) | jchow | FloEFD, FloWorks & FloTHERM | 1 | January 16, 2012 17:03 |
FDTD Simulation of flow through tapered pipe | Jim | Main CFD Forum | 3 | December 25, 2006 11:56 |
