Custom thermophysical model causes problem with compressibleMultiphaseInterFoam
Old   April 27, 2022, 08:29
Default Custom thermophysical model causes problem with compressibleMultiphaseInterFoam
R4z0rX is on a distinguished road
Hello everyone,
I am facing a problem using my own custom thermophysical model in conjunction with the compressibleMultiphaseInterFoam solver.
The thermophysical model is using the following setup:
type            heRhoThermo;
mixture         pureMixture;
transport       polynomial;
thermo          hPolynomial;
equationOfState PengRobinsonGas;
specie          specie;
energy          sensibleEnthalpy;
This causes the solver to post the following error:
--> FOAM FATAL ERROR: (openfoam-2112)
Supported energy type is e.fluid, thermodynamics package provides h.fluid
From void Foam::basicThermo::validate(const Foam::string&, const Foam::word&) const
in file basicThermo/basicThermo.C at line 485.
FOAM exiting
I suppose the solver's energy equation is in terms of internal energy and not enthalpy. However, I cannot choose sensibleInternalEnergy as an option with the PengRobinson EOS formulation.
Is there a way to get this to work? Any hints are highly appreciated.
Best regards
R4z0rX is offline   Reply With Quote
compressible multiphase, pengrobinsongas, sensibleenthalpy, thermophysical model
Custom Lagrangian Phase Change Model craven.brent OpenFOAM Programming & Development 4 December 25, 2022 20:22
[swak4Foam] swakExpression not writing to log alexfells OpenFOAM Community Contributions 3 March 16, 2020 19:19
Problem with k-epsilon model torkness FLUENT 2 February 27, 2015 03:44
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Air-lift model with hot gases and water. Time step problem. PauliusRap FLOW-3D 0 August 4, 2014 05:47
