Compatible BCs for thermally conductive internal wall using chtMultiRegionFoam |
April 26, 2022, 10:41 |
J Collins
Rep Power: 11 |
I am attempting to use chtMultiRegionFoam to simulate thermal conduction between two materials that are directly connected. I have two regions that share a wall, and I would like to have a simple continuity boundary between them.
The calculatedFvPatchField is not compatible with mapped walls, so I'm struggling to see which BC suits the need. |
April 26, 2022, 11:31 |
Have you tried coupled boundary condition ?
compressible::turbulentTemperatureRadCoupledMixed |
April 26, 2022, 12:31 |
Solved
J Collins
Rep Power: 11 |
Well that seems to have worked. How did you discover this BC and how is it applicable to this case?
April 26, 2022, 13:03 |
Its in tutorials and moreover I have worked with multiregion models.
https://develop.openfoam.com/Develop...DictionaryDict |
April 27, 2022, 04:28 |
J Collins
Rep Power: 11 |
I searched everywhere for a tutorial showing two solids attached and conducting, but found none.. How did you come across yours?
April 27, 2022, 04:53 |
Kindly look into chtMultiRegionSimpleFoam tutorial. It solves heat conduction equation in the solid domain, where you can use multiple regions (solid or fluid) and connect regions using coupled boundary condition.
For further information, check this forum page: How to solve a heat conduction between two different solid materials ? In post no. 8, Mr. Tobi has attached a solver for 2 solid domains. Hope it helps you. Thank you |
cht modelling, conduction-diffusion |
Enhanced Wall Treatment | paduchev | FLUENT | 24 | January 8, 2018 11:55 |
Internal wall boundary condition | ivan-s | COMSOL | 0 | October 8, 2014 16:09 |
[ICEM] Merge meshes with internal wall | BrolY | ANSYS Meshing & Geometry | 20 | February 20, 2013 10:43 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
Wall BC's for a NS solver | André Burdet | Main CFD Forum | 6 | December 8, 2000 21:45 |
