Hoping for help with boundary conditions in chtMultiRegion case |
April 25, 2022, 13:59 |
Alan w
Rep Power: 6 |
Hello again,
After receiving greatly appreciated help in setting up a radiator-in-a-duct case, I set about putting it to use in a real task. It ran successfully with one specified radiator temperature, but when I changed T to a different value, it failed; here is a snippet of the output message: Code:
[1] 68 1069.52 397373 1162.17 1068.2 [1] 69 1068.2 394396 1162.06 1069.45 [1] 70 1069.45 397209 1162.16 1068.27 [1] 71 1068.27 394551 1162.06 1069.38 [1] 72 1069.38 397064 1162.16 1068.33 [1] 73 1068.33 394689 1162.07 1069.33 [1] [1] [1] --> FOAM FATAL ERROR: [1] Maximum number of iterations exceeded: 100 [1] [1] From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const, bool) const [with Thermo = Foam::hPolynomialThermo<Foam::icoPolynomial<Foam::specie> >; Type = Foam::sensibleEnthalpy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hPolynomialThermo<Foam::icoPolynomial<Foam::specie> >, Foam::sensibleEnthalpy>] [1] in file /home/ubuntu/OpenFOAM/OpenFOAM-8/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 106. To make it easy to see where I'm at currently, I collated my BCs and some schematics on the attached Excel file. Also attached is the run script for the case. I need help with finally getting a handle on the proper set of boundary conditions. The tutorials give a little help, but don't really cover my case, and I have fought with this at length, and with little success. Hoping for help, and/or pointing to the right set of resources. |
April 27, 2022, 15:39 |
should the 2 regions have similar cell size for chtMultiRegionFoam?
Alan w
Rep Power: 6 |
I am continuing to struggle with my chtMultiRegion radiator simulation case. My simple template case seems to work, but when I put in more complex geometry, it fails with the "maximum number of iterations exceeded:100" message.
Attached is an image that shows the geometry I'm working with. It's basically an airplane fuselage with a radiator in a ventral fairing. To assess the mesh, I took out the radiator and ran it as a simpleFoam case, and it worked. But with the radiator, it always fails. My boundary conditions are defined in my previous post. Now, my theory is that in the overlapping region, the solid and fluid cell sizes should be similar. In the image, the relative cell sizes can be seen, with the two regions shown separately. They are close, but not identical. Again, the run failed. Is my mesh theory correct? If so, how close should the cell sizes be? I am hammering away at this, but not getting anywhere. But I will not give up!! Nevertheless, am hoping for some advice to save me time and frustration. |
April 27, 2022, 23:44 |
I didn't read your entire contents posted here. To be more precise, are you looking for Coupling boundary condition between the multiregions ? Have you refereed multiregion tutorials for appropriate boundary conditions and relevant forum pages ?
Thank you |
April 28, 2022, 15:31 |
Thanks Kummi, but not there yet
Alan w
Rep Power: 6 |
My case is a porous solid zone , immersed in a fluid zone, so it should be coupled? At any rate, based on your observation, I looked at the heatExchanger tutorial in v2012 (I typically use OF8), and noted that the alphat BC had the format that you referred to. So I used that tutorial as a template for my boundary conditions. Unfortunately, it failed again, with the same "maximum number of iterations" message. Here is part of the runlog:
Region: fluid Courant Number mean: 241.035 max: 74441.5 Region: solid Courant Number mean: 0.043849 max: 0.698227 Time = 2 Solving for fluid region fluid DILUPBiCGStab: Solving for Ux, Initial residual = 0.0375302, Final residual = 0.00117791, No Iterations 1 DILUPBiCGStab: Solving for Uy, Initial residual = 0.0561504, Final residual = 0.00239053, No Iterations 1 DILUPBiCGStab: Solving for Uz, Initial residual = 0.20625, Final residual = 0.00923548, No Iterations 1 DILUPBiCGStab: Solving for h, Initial residual = 0.947747, Final residual = 0.093489, No Iterations 5 From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const, bool) const [with Thermo = Foam::hPolynomialThermo<Foam::icoPolynomial<Foam::specie> >; Type = Foam::sensibleEnthalpy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hPolynomialThermo<Foam::icoPolynomial<Foam::specie> >, Foam::sensibleEnthalpy>] in file /home/ubuntu/OpenFOAM/OpenFOAM-8/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 70 Energy -> temperature conversion failed to converge: [0] iter Test e/h Cv/p Tnew [0] 0 551.55 -161588 1049.09 1083.62 [0] 1 1083.62 208023 1163.19 1245.74 [0] 2 1245.74 740039 1146.09 946.085 [0] 3 946.085 -44205 1142.75 1331.83 [0] 4 1331.83 955187 1106.82 827.155 [0] 5 827.155 -76472 1113.93 1251.85 [0] 6 1251.85 757385 1144.13 936.514 [0] 7 936.514 -50041.2 1140.67 1328.08 [0] 8 1328.08 947052 1109.1 831.775 Attached is an excel file that shows all of the patch boundary conditions, as well as the initial conditions. Truly hoping for help, so I can get past this logjam! |
April 29, 2022, 03:26 |
#5 | |
Checking your error at line number 70 in thermoI.H
This solves temperature (T) variable using Newton-Raphson method. That's clear for now. Here the links that might help you. chtMultiRegionFoam "thermoI.H" Not Converging Highly unstable buoyantPimpleFoam simulation Have you came across the posts ? Thank you |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 16:13 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 14:55 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 05:39 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 15:53 |
